Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
throttle and kickdown linkage question on L-48
« previous
next »
Print
Pages: [
1
Author
Topic: throttle and kickdown linkage question on L-48 (Read 4027 times)
Flowjoe
Member
on:
August 06, 2008, 03:52:52 PM »
Hello All,
I posted in the restoration area but don't think there is as much traffic as here. I need to know two things:
1) which of the three holes (at he top of the carb linkage) in the photo below is correct for "sticking" the throttle linkage through? I can't seem to tell from the AIM
2) is the bolt/tab correct for the kick-down linkage on a TH350? Is it in the correct location?
Tweet
Logged
KevinW
Hero Member
Re: throttle and kickdown linkage question on L-48
Reply #1 on:
August 06, 2008, 06:41:45 PM »
good question, I am pretty sure its the front-most one. The way to tell is take linkage off put pedal to the floor, carb is wide open, see where the best lineup is. The upper holes give the best throttle reponse because of the larger arc.
Logged
Flowjoe
Member
Reply #2 on:
August 06, 2008, 07:18:19 PM »
Thanks for the response Kevin.
A follow up question would be whether the stud on the threaded throttle linkage goes in from the outside or from the inside. Anyone?
Logged
Sauron327
Hero Member
Reply #3 on:
August 06, 2008, 09:27:07 PM »
Outside. Do you have the correct stud with the retaining clip?
Logged
Flowjoe
Member
Reply #4 on:
August 06, 2008, 10:26:30 PM »
Repro piece, uses cotter pin rathe than the clip you refer to.
Logged
Print
Pages: [
1
« previous
next »
General Discussion
