Author Topic: Please see picture of my 327 - question on originality  (Read 15328 times)
DonSTP
  • 68-RS
« on: February 11, 2006, 01:40:26 PM »
I've got a 327/210, and I'm bringing it back to original.
Notice the color of the engine block.  I plan to paint this back to the original orange but I'd be open to any feedback on what else may need to be done.
The alternator is incorrect, which may be the cause of my blown fuses.  I've purchased the correct alternator (amp rating) and will reinstall.
Notice the chrome valve covers and chrome air cleaner.  Are these supposed to be orange, black - or another color?  I can't seem to find the correct non-chrome valve covers, which makes me think they were chrome from factory?
Is the air cleaner supposed to be the black snorcle-type?
Thanks for your assistance.
I've got a beauty - 36k original, documented miles, all driven in CA except for last 2k!
wtexz10
Re: Please see picture of my 327 - question on originality
« Reply #1 on: February 11, 2006, 04:55:07 PM »
I'm not sure about most of your questions, however I no that the orange Ford Caution sticker on your fan shroud is incorrect.
 ;)  Kris
69 Camaro Z10.. 72 GMC C1500
79 Mazda RX7.. 79 Trans Am WS6
06 Corvette Z06.. 10 BMW 650i
danh3508
« Reply #2 on: February 11, 2006, 06:13:44 PM »
the 327 came witha single-snorkel, closed element air cleaner. the steel valve covers were painted orange. the 350ci used chrome valve covers.  the carb was 2 barrel rochester.
Steve68
« Reply #3 on: February 11, 2006, 08:51:25 PM »
DonSTP
When you say you want to "bring it back to original" that probably means different things to many of us.  Can you be a little more specific in what you're wanting to accomplish?  Did you say what year the car is?  I may have missed that but some basic info would help.  Manual or automatic?  3/4 speed?  Power steering?  For instance, you no doubt already know the rad cap and plug wires are not original just from their appearance but we are not able to help you with thing like the carb without numbers.  Are you going to add smog equipment if 67-69?  Take more pictures from different angles and post them.
« Last Edit: February 12, 2006, 07:20:44 PM by Steve68 »
rich69rs
  • LF7/M35/Z22/Z87
« Reply #4 on: February 13, 2006, 05:46:27 PM »
Although you didn't state it, since the oil fill tube is in the front of the intake, this isn't a 69.
Attached to this e-mail is a pic of the correct 327 - 210 HP engine for a 69.  I will post 3 additional pics in seperate posts to follow.  The engine pictured is the correct engine for my 69 RS, which I installed last summer.  My car has a PowerGlide, so it also has the heat tube / snorkel assembly to the air cleaner EFE (early fuel evaporative) system.  To the best of my knowledge, 3 spd manual cars did not have EFE.
I think that in '68, the air cleaner was turned in the opposite direction, with the snorkel pointing toward the driver side.  I have what I believe is a '68 air cleaner and it is oriented that way.  Never confirmed it though once I realized it was not the correct air cleaner for my car.
Richard Thomas
1969 RS
rich69rs
  • LF7/M35/Z22/Z87
« Reply #5 on: February 13, 2006, 05:47:03 PM »
Pic #2
Richard Thomas
1969 RS
rich69rs
  • LF7/M35/Z22/Z87
« Reply #6 on: February 13, 2006, 05:56:28 PM »
Pic #3, Transmission mounted.  Note valve covers are not the ones in pics #1 and #2.  They are spares that were used during the engine installation.  Restored valve covers mounted later after engine and transmission were installed.
Richard Thomas
1969 RS
rich69rs
  • LF7/M35/Z22/Z87
« Reply #7 on: February 13, 2006, 05:57:11 PM »
Pic #4  Same note applies as indicated in pic #3.
Richard Thomas
1969 RS
rich69rs
  • LF7/M35/Z22/Z87
« Reply #8 on: February 13, 2006, 06:08:12 PM »
Two more pics - after the engine is in the car
Richard Thomas
1969 RS
rich69rs
  • LF7/M35/Z22/Z87
« Reply #9 on: February 13, 2006, 06:09:32 PM »
Pic #2 - engine in the car
Richard Thomas
1969 RS
strat01
« Reply #10 on: March 18, 2006, 06:36:56 AM »
67 327 had orange covers w/o holes in them had oil filler in front of the intake alt above the pwr steering pump no air heater on the blk air can
westonz28
« Reply #11 on: March 19, 2006, 04:19:36 AM »
I thought the 1967 small block low HP. Camaro's had the Chevrolet script on the valve covers. Only Camaro to have this. 1968 and later had plain valve covers. Is this correct?
67 RS L30/M20 numbers, 68 BB 396 12 bolt posi
68 Z28 project, 68 numbers 327/210 4 speed
69 LM1 turbo 350 12 bolt numbers,70 L65 350
68 Chevelle L30 3 on the tree, 68 El Camino BB
« Reply #12 on: March 05, 2012, 11:10:47 PM »
Hey Rich,
Very nice detail on the motor, looks like a nice install. One question why go through so much work getting the motor spot on, but then run Z/28 stripes on the car? I am not trying to insult you just curious since the engine compartment looks so factory correct. thanks
RAfbody
« Reply #13 on: March 06, 2012, 02:06:37 AM »
That is correct.
Russ
« Reply #14 on: March 06, 2012, 02:21:37 AM »
Photo below is from a '68 RS 327cid/210hp with A/T...
« Reply #15 on: March 06, 2012, 02:28:00 AM »
Looks very original. Looks like the valve covers just got resprayed, but everything else looks untouched, other than the cap on the oil fill.
rich69rs
  • LF7/M35/Z22/Z87
« Reply #16 on: March 06, 2012, 05:23:16 AM »
Hey Rich,
When I purchased the car in Nov 1991, it was painted as you see it - and still is.  Over the years, the mechanical aspects have all been dealt with and all that's left is to have the 20' paint job fixed.  Existing paint will need to be stripped - car was originally Dover White and someone painted it baby blue with the Z stripes prior to me acquiring it in '91.
Richard
Richard Thomas
1969 RS
rich69rs
  • LF7/M35/Z22/Z87
« Reply #17 on: March 06, 2012, 05:26:53 AM »
In Paul's picture you see some of the differences between '68 327/210 and '69 327/210 (or 307/200).  In '68, air cleaner snorkel and alternator are on driver's side, in '69 on the passenger's side.
Richard Thomas
1969 RS
« Reply #18 on: March 06, 2012, 05:41:50 AM »
I look forward to seeing it in white, would it have had some sort of factory striping? seems like it would with the options your car has, maybe some side accent striping or something? I commend you on the job you have done thus far.
MyRed67
  • SZZLN 67
« Reply #19 on: March 06, 2012, 07:55:10 AM »
((I thought the 1967 small block low HP. Camaro's had the Chevrolet script on the valve covers.))
(( That is correct))
Seeing that most pics. are of '68 and '69's, I thought I would post a pic. of my original '67  327/210 w/Powerglide  Air Cleaner/Carb./Intake and painted Script Valve covers.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
