Author Topic: Cowl Induction with A/C  (Read 8184 times)
gearheadtx
« on: June 17, 2008, 08:59:06 PM »
Has anyone out there tried a cowl induction with A/C in a 67.  I have 67 with factory A/C and am not sure where to connect up the cowl connection.
Mark
Re: Cowl Induction with A/C
« Reply #1 on: June 18, 2008, 03:08:09 PM »
The power feed for the relay for the flapper door solenoid just needs to be connected to a switched 12V source at the fuse block, like the "IGN" or "ACC" cavity.
Mark
« Reply #2 on: June 18, 2008, 04:07:30 PM »
I think he's talking about the old cowl induction ductwork that connected to the firewall, before GM cam out with the cowl induction hood.  If so, theres no way to do it, since the A/C suitcase sits right were the connection to the firewall was made.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
gearheadtx
« Reply #3 on: June 18, 2008, 05:45:08 PM »
i actually have installed a cowl induction hood on my car.  My hope is to get it working the right way but not sure whether can make it work with the A/C suitcase in the way.
Mark.
« Reply #4 on: June 19, 2008, 03:33:58 PM »
Mark.
There's nothing about an A/C car that interferes in any way with the ZL2 hood setup; it was available on SS cars with or without A/C.
gearheadtx
« Reply #5 on: June 19, 2008, 04:20:58 PM »
Thank you much for your replies.  I was wondering if the set up is in the assembly manual or where would I find the schematics for the set up of the Cowl system.
tom
    • Discount Internet Services
« Reply #6 on: June 20, 2008, 01:19:28 AM »
Try the 69 AIM - UPC ZL2 at the very end of the book
Tom
69 X11 Z21 L14 glide
o
BlackoutSteve
« Reply #7 on: June 29, 2008, 07:28:43 AM »
Mark.
I'm pretty sure GearheadTX is talking about the cowl induction ducting that went from aircleaner to cowl through the firewall in a 67. Not a using cowl hood.
« Last Edit: June 29, 2008, 07:34:48 AM by BlackoutSteve »
Restoring my RHD 69 Jane in Melbourne, Australia.
http://www.usmuscle.com.au/Forum/showthread.php?t=2840
click
    • Our 69 RS
« Reply #8 on: July 01, 2008, 09:49:11 PM »
Maybe this article I had on file can help you see the layout. :)
Click is Jim , central Minn.  Moderator at Team Camaro www.camaros.net
