Author Topic: muncie four speed correct TANGED gaskets  (Read 3019 times)
john302
« on: May 04, 2008, 04:56:27 AM »
Does anyone know were to purchased the true correct gaskets for a muncie trans. The gaskets  are the ones betwwen the main case and tail housing.The original gaskets have a tang on the edge that sticks out.All of the rebuilders are using the replacement gasket without the tang and are incorrect.  Thanks John
Jerry@CHP
Re: muncie four speed correct TANGED gaskets
« Reply #1 on: May 05, 2008, 12:08:22 AM »
You have to use an original GM gasket set.  Think if I remember the number is 3917763.
Jerry
john302
« Reply #2 on: May 10, 2008, 03:06:02 AM »
Found a nos set  :) Thanks for the info
