Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Originality
Rocker Arms SBC with "O" on the end
« previous
next »
Print
Pages: [
1
Author
Topic: Rocker Arms SBC with "O" on the end (Read 5618 times)
opelitis1
Member
on:
April 30, 2008, 05:28:11 PM »
Small block rocker arms with the "O" on them... I have heard that these are better than the more common "V" type... Why??? I have maybe 15 of these O arms and cannot see any difference..
Maybe it is my vision, eh??? Ted
Tweet
Logged
Hero Member
caretaker of 1971 LT1's 11130 & 21783
Re: Rocker Arms SBC with "O" on the end
Reply #1 on:
April 30, 2008, 08:25:51 PM »
The slot in an O arm is supposed to be longer for the high lift cams.
Logged
PACE&Z2869
Member
Reply #2 on:
April 30, 2008, 08:28:35 PM »
I believe the "o" stamped rockers are a long slot rocker for higher performance engines. The newer rockers are also long slot as GM probably wanted to standardize a p/n. As opposed to the older low performance rocker arm which wasn't a long slot. Higher lift camshafts required a long slot rocker.
Logged
PACE&Z2869
opelitis1
Member
Reply #3 on:
May 01, 2008, 09:48:48 AM »
How old are these "O" Rocker arms and were they in fact specific to a certain engine or car model??? I've had them for 10 years and the person I bought them from must've had them for maybe another 10 years B 4 me.... In the olden golden days, what did we in fact consider a "high lift" cam?
Anything over .450 and were they used in "solid lifter" cams only???
Logged
CRG Member
Reply #4 on:
May 01, 2008, 03:42:04 PM »
The "o" rockers are also heat-treated differently for durability; the lash clearance on solid-lifter engines is much harder on the rockers than the constant zero-clearance of hydraulic lifters.
Logged
opelitis1
Member
Reply #5 on:
May 01, 2008, 04:30:29 PM »
Good info Mr JohnZ... Had these for sooo many years and basically never knew what I had or why and what they were used on.... Merci!!! Ted
Logged
Print
Pages: [
1
« previous
next »
Originality
