Author Topic: Possible find 67 L30/M20  (Read 33181 times)
Jeffro67
Re: Possible find 67 L30/M20
« Reply #15 on: April 21, 2008, 06:51:08 AM »
Jeffs 67.
Jeffro67
« Reply #16 on: April 21, 2008, 06:51:49 AM »
Jeffs 67.
Jeffro67
« Reply #17 on: April 21, 2008, 07:03:23 AM »
Jeffs 67.
Jeffro67
« Reply #18 on: April 21, 2008, 07:06:41 AM »
Ok, newbie is a perfect name for me. On theese last two pics I found out how to reduce them way further.
Jeffs 67.
rare4k
« Reply #19 on: April 21, 2008, 12:25:56 PM »
I think the rear is wrong just by date, should be a 12 bolt round bar,Ithink the car may have had a saginaw trans thats why the cable is on the drivers side, I haven't seen a saginaw in along time I can't remember what side it's on, Also just a NOTE you have a big block cross member  great color when done
Jeffro67
« Reply #20 on: April 22, 2008, 12:26:22 AM »
Thanks, I agree, I have seen a few pictures of Mountain Green cars and I like them.
 What is the difference between big block and small block cross members?
Jeff.
Jeffro67
« Reply #21 on: April 22, 2008, 05:52:41 AM »
Hey all, I was just researching the forum and I noticed that my early 67 has the same plastic speedo cable plug in the same hole (just above and right of throttle lever) as qwertyme77 posted under decoding/numbers board on March 26. What's up?
Jeff.
Jeffro67
« Reply #22 on: April 22, 2008, 06:03:15 AM »
Does anyone know if GM used different size fuel lines on 67 models for different engine applications?
Jeff.
Jeffro67
« Reply #23 on: April 22, 2008, 08:05:29 PM »
It looks like (qwertyme77) 67 is very close to mine. His has a tag build of 01B and my car is 02B and both 4 speed cars. Does any one know if I can message him directly so I can catalog the similarities?
Jeff.
« Reply #24 on: April 22, 2008, 09:30:02 PM »
Sure, just click on his user id, then on "send this member a personal message".
Stillwater Camaro
« Reply #25 on: April 23, 2008, 01:50:46 AM »
Jeff.
That's not a speedo cable plug. It is a 2 wire electrical bulkhead connector.
1967 Camaro SS/RS 350
1966 Chevelle SS 396
1970 Chevelle SS 396
1967 GTO
Jeffro67
« Reply #26 on: April 23, 2008, 03:47:22 AM »
Thanks for clarifying that electrical connector for me, I can clearly see the other two holes now.
Jeff.
« Reply #27 on: April 23, 2008, 04:33:25 AM »
Reverse light hookup
Jeffro67
« Reply #28 on: April 23, 2008, 06:29:31 AM »
Can anybody direct me to a picture of a 67 radius rod (bracket) that is allready bolted to the bottom of the floor pan?
« Reply #29 on: April 23, 2008, 04:29:15 PM »
Sure, see page 81 in Jerry MacNeish's "The Definitive 1967-1968 Camaro Z/28 Fact Book", third edition.     :)
