CRG Discussion Forum
Welcome, Guest. Please login or register.
Did you miss your activation email?
June 19, 2013, 08:18:25 PM
Search:     Advanced search
Forum registration problems: Make sure you enter your email correctly and you check your spam box first. *Then* email KurtS2@gmail for help.
83204 Posts in 10595 Topics by 4407 Members
Latest Member: georgeshaw
* Home Help Search Login Register
+  CRG Discussion Forum
|-+  Camaro Research Group Discussion
| |-+  Mild Modifications
| | |-+  Multi-leaf to mono-leaf axle housing installation
« previous next »
Pages: [1] Print
Author Topic: Multi-leaf to mono-leaf axle housing installation  (Read 2223 times)
chd3
Newbie
View Profile
« on: April 06, 2008, 01:20:24 PM »
I am installing a 12 bolt with multi leaf mounting perches on mono leaf springs. Does anyone know if spacers and pads are made for this conversion. I do not want to cut and replace the perches on the axle housing? Thanks.
Logged
Hero Member
View Profile
« Reply #1 on: April 06, 2008, 01:48:49 PM »
Why not just install a pair of multi-leaf springs?
http://store.heartbeatcity.net/store/product/16815/Leaf-springs%2C-4-leaf%2C-correct/
Logged
Ed Bertrand
CRG Member
View Profile WWW Email
« Reply #2 on: April 06, 2008, 02:23:47 PM »
Quote
Not that I know of. Since the multi leaf spring perch is much deeper than the mono leaf perch, you're going to have to make some kind of spacers to take up the slack. I don't recommend wooden blocks, but something like aluminum might work. Steel would be better, but cutting this would be more difficult than aluminum.
Logged
Ed Bertrand
CRG Member
dd442
Member
Gotta Love a Big Block
View Profile
« Reply #3 on: April 07, 2008, 09:13:18 AM »
I have used a cut block of aluminum and also used composite fiber blocks that work well.
Logged
70 SS 396\350, 69jane, 69 442, 70 Mach 1
Pages: [1] Print
« previous next »
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Page created in 0.099 seconds with 17 queries.
