Author Topic: 68 Z28 fan blade  (Read 8307 times)
68 Z28 fan blade
« on: March 16, 2008, 02:08:43 AM »
Is the main difference in the solid lifter fans and the low perf. ones the bolt cir dia. for the fan clutch?  Are both the fans the same diameter (18"s), shape etc.  Reason I am asking is, the Z28 ones are ridiculously priced and if the others are functionaly the same, you could just get the right clutch for the cheap one and have the same results?
Re: 68 Z28 fan blade
« Reply #1 on: March 16, 2008, 05:31:25 PM »
Functionally, the 5-blade fans and clutches with a 3" bolt circle will work, but they're not judging-correct. Z/28 and L-78 used the clutch and fan with a 3-1/4" bolt circle.
lakeholme
  • 68-12D L30/M35
« Reply #2 on: March 16, 2008, 07:03:39 PM »
You can see that here:
http://www.camaros.org/coolingsystems.shtml
"Fan for L78 and Z28 and 1968 L34/L35 with K02
The 3871276 fan was used on the 1967 and 1968 Z28 and L78, as well as 1968 L34/L35 with K02. The bolt circle diameter for the clutch-to-fan attachment was 3.25-inch. It thus required a different clutch unit than the fan clutches used with the AC or K02 hydraulic lifter engines.
Five-Bladed Fans for 67-68
(Note the difference in the center hole diameter.)"
So, John, by "functionally" are you telling 68Zproject that the 3" bolt circle fan and clutch will fit or does it require some modification?
fireZ
« Reply #3 on: March 16, 2008, 08:46:31 PM »
Both fans work the same. I have an original one on green 68 Z and the smaller dia. one on my blue 68 Z . I have looked for an orig. fan for the blue car but the price scares me off. When i bought the blue car the original owner told me he had a flex fan on the car since the early 70s because he hated the noise the original clutch fan made. Said he remembers throwing out the original.
1968 Z28 LA Built
LIC # RPO Z28
« Reply #4 on: March 16, 2008, 11:07:39 PM »
Nice. :'(
I'm going to do what firez did.  That's why I needed to know if they were functionally the same.  Some day when I win the Lotto I'll get the real fan.  Thanks much. ;D
Jerry@CHP
« Reply #5 on: March 18, 2008, 02:00:29 AM »
Yes, the 3" hole fan blade will work fine.  Try to get one that has four rivets instead of five.  The 3" fans come both ways.  Just buy a clutch to match it and use as is.
Jerry
« Reply #6 on: March 18, 2008, 02:45:47 AM »
Are the 4 rivets better in function ot do they just look more like the 3.25"?
« Reply #7 on: March 18, 2008, 02:54:39 AM »
The original Z/28 fans use 4 rivets per blade.
« Reply #8 on: March 18, 2008, 03:43:32 AM »
And to answer the original question, there was a difference in function or they wouldn't have used the unique part. But it's obviously not much of a difference... :)
« Reply #9 on: March 18, 2008, 04:02:48 AM »
Jerry's book just said the larger bolt circle was because of the higher RPM of the solid lifter engines.  Other than that I mainly wanted to make sure it was the same diameter and the cooling would be the same.
Jerry@CHP
« Reply #10 on: March 18, 2008, 11:44:18 AM »
Dave Libby, an engineer from GM pulled the blue prints and that's what was stated on the prints about the diameter and why it was larger.
Jerry
« Reply #11 on: March 19, 2008, 12:57:28 AM »
I'd like to have those blueprints and make a real repo out of quality stuff that looked and fit like the real thing, instead of skipping a house payment to buy one.
