Author Topic: Id a balancer &  (Read 6359 times)
bob69
Id a balancer &
« on: January 27, 2006, 06:06:19 PM »
I need help finding out if I have the right balancer & cover for a 69-302. It's 8" & The cover has a seprite tab with the marks on it It sits at about 2:00.ON the balancer Any help & pics would be great. Thanks Bob
Re: Id a balancer &
« Reply #1 on: January 28, 2006, 03:18:33 AM »
Photo below of a correct original '69 DZ302 timing cover - the timing tab is welded to the cover. Photo also of a 302 8" balancer scribed to show both timing index marks - note that the timing index mark for '68 usage is directly in line with the crank keyway and a pulley bolt hole, and the '69 timing index line was moved counter-clockwise about ten degrees from the keyway positiion, which also generated a different timing cover and tab to match the relocation. Don't mix a '68 balancer and a '69 timing cover, or vice versa, or your timing tab marks will be out of whack.
Re: Id a balancer &
« Reply #2 on: January 28, 2006, 03:20:01 AM »
Second photo of the balancer didn't show up in the above post - here it is.
