Main Menu
1969 power brake master cylinder cap wording
Started by john302, March 08, 2008, 09:27:36 PM
Previous topic - Next topic
john302
Does anyone know when they changed the power brake master cylinder cap wording? The early caps have  USE DELCO BRAKE FLUID stamped in the cap ,and the later ones have USE DELCO SAEJ1703 BRAKE FLUID.  ??????????? around what month in 69 did they change????????
rich69rs
The master cylinder on my '69 RS is for power drum brakes.  My car is an 01C Norwood build; Final assembly on or about the 20-21 Jan 1969; VIN #19N581767
On the front of the master cylinder cap it says:
SERVICE WITH DELCO PARTS
On the rear of the master cylinder cap are the words:
Richard Thomas
1969 RS
L78 steve
I'll let you know what my 105 date master cylinder cap reads when I get it back from the plate-r .
69 Z/28 Dover White. SOLD
L78 steve
04C car build,105 master cylinder.Cap reads ,Service With Delco Parts. And Use Delco Brake Fluid SAE J1703 .
BillG
Mine says something completely different.  O3B built, power front discs.  It reads:                   WARNING CLEAN FILLER CAP BEFORE REMOVING,  and  USE ONLY DOT? FLUID FROM A SEALED CONTAINER.  Cant read the # after DOT because of pitting.
Bill Garrett
