Main Menu
Original "Endura" bumper brackets & mounting hardware
Started by nuch_ss396, February 19, 2008, 08:16:00 PM
Previous topic - Next topic
nuch_ss396
Hi all!
I'm working on a '69 Camaro project and I need the original mounting brackets & hardware for the "Endura" bumper.  I know repro's are available, but I only want original
components.  Here is an image I found of an orignal outer bracket ( assembled ) to the bumper.  I'd like to see these components separated so I can see exactly what
real ones look like.  The socket head cap screw used to attach the bracket to the bumper is also critical.
Can anyone post one or more images of the original outer bracket(s), bushings, bolts?  Also, I'd like to see what the original bolts looked like that attached
the inner brackets to the bumper as well.
Finding this stuff (correct) is like hens teeth.
Steve A.
I would be content to let sleeping dogs lie. Blast and paint as is. Lean on that screw and either it will break or the sleeve in the steel liner of the bumper will break.
If you must, try loosening the screw with very light force.
nuch_ss396
William,
Thanks for responding.  Please allow me to clarify:  I own a pristine Endura bumper, but it does not have any of the attaching hardware.
The image I posted is of one I found online.  I don't own it, just merely posted an image to clarify my point.  My main problem is that I
can't seem to find what the original bracketry & mounting hardware looked like.
Steve A.
smith69z
I'll get pics out tonight of an original set that came on my car.
nuch_ss396
Steve A.
Steve -
Here's a couple of endura bumper bracket photos I came across...
hihorse
Here is an original set I took off personally from a X44 car dated 12C, sorry don't have the bolts
http://www.camaros.net/classifieds/showproduct.php?product=24364&cat=8
nuch_ss396
hihorse,
Your brackets are the inners - I'm looking for the outers at this point.  But I will consider them ;D
Steve A.
asm69
I took pictures of my original Endura bumper brackets. These brackets are mounted to the frame extension.
I'm not sure if this is what your looking for if you need the pictures of the other brackets let me know.
1969 z28 body build date 10D (October of 1968) LOS plant.
asm69
asm69
Passenger side brackets.
asm69
nuch_ss396
Thanks asm69 !
Yes - I'd love to see the same type of images for the outer brackets too.  Those are the ones I'm trying to locate cirrently.  If you can manage to separate the
original internal hex head bolt that holds the outer bracket to the bumper, that would be fantastic.
Steve A.
Ed Ernst
1967 SS/RS convertible - LA 12A built
nuch_ss396
Ed!
You're the man!!  That's exactly what I wanted to see.
OK - how much for them? seroiusly!!!
Nuch
Steve A.
Ed Ernst
Glad the pics helped.  The brackets belong to a friend and are part of the full set he has, so are nfs.  I do see these on Ebay from time to time.
Quote from: nuch_ss396 on February 19, 2008, 08:16:00 PM
Hi all!
components.  Finding this stuff (correct) is like hens teeth.
Hi Steve -
I don't know if you're still looking, but here's a complete set on Ebay up for grabs...
http://cgi.ebay.com/ebaymotors/1969-Camaro-Endura-Bumper-Bracket-Set-Original-GM_W0QQitemZ230253650109QQihZ013QQcategoryZ33640QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
