Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Maintenance
ignition lock removal
« previous
next »
Print
Pages: [
1
Author
Topic: ignition lock removal (Read 7872 times)
camaromikey
Member
on:
February 10, 2008, 10:00:10 PM »
im having a little trouble getting the ignition lock out of the column. the column is out of a 1969 firebird orignnally. i have everthing out of the way. i removed the signnal switch and everything. this column has the threaded hole for retaining pin but it doesn't go all the way down and there was no pin. also i don't have a key for it but the lock is broken and i can turn it from lock to run without the key. any ideas, you guys have always be great
Tweet
Logged
Gramps69Z
Hero Member
69 X33 D80
Re: ignition lock removal
Reply #1 on:
February 10, 2008, 11:42:56 PM »
Insert screwdriver or similar tool into the slot in the housing. Depress the spring latch at the lower end of the cylinder. With the latch depressed, remove cylinder from housing.
Logged
Captain John Wykoff
Destin Fire: October 31, 2015 at 0700--Officially Retired
camaromikey
Member
Reply #2 on:
February 10, 2008, 11:59:47 PM »
is the slot on the outside or the inside?
Logged
Gramps69Z
Hero Member
69 X33 D80
Reply #3 on:
February 11, 2008, 03:45:02 AM »
Inside under the turn signal switch. Look near the end of the cylinder.
Logged
Captain John Wykoff
Hero Member
Reply #4 on:
February 11, 2008, 10:28:14 PM »
For a picture of the exact location, see page 9-10 in your 1969 Chevrolet Chassis Service Manual.
Logged
camaromikey
Member
Reply #5 on:
February 12, 2008, 12:28:24 AM »
could you post a picture, i still can't find mine from when i moved. there are only two openning, one had the brass contract in it and the other has the lever that moves for the ignition switch in it but i can't get to the lock cylinder.
Logged
CRG Member
Reply #6 on:
February 12, 2008, 03:46:47 PM »
Try this
Logged
camaromikey
Member
Reply #7 on:
February 13, 2008, 12:02:27 AM »
thank guys you have been a big help.
Logged
Print
Pages: [
1
« previous
next »
Maintenance
