Author Topic: Can anyone think of a GM delay wiper switch NOT on the steering column?  (Read 11210 times)
sdkar
He guys,
I am trying to upgrade to delay wipers on my 69 Camaro by using a 4th gen Camaro wiper motor.  However, as you all know, it is extremely common that GM put the delay controls on the turn signal.  Can anyone think of and suggest a vehicle that has delay wipers but uses a conventional switch that can be installed on the dash.  I am going to visit my local junkyards and see what I can find.  If anyone has an idea, let me know.  If we can figure this out together I will be happy to share the completed innovation steps for the upgrade.  So far I have the motor and the harness from a 4th gen at a cost of $15 for everything.  If I can find a switch that will work than I am sure I can configure a delay wiper system that we can all have for under $20.
red69
Re: Can anyone think of a GM delay wiper switch NOT on the steering column?
« Reply #1 on: February 06, 2008, 03:59:31 PM »
I'm just going from memory here, but I think an early around 75 Monte Carlo"s and probably others of that vintage had a dash switch. I believe it had a slide control with a twist knod to control delay. Could be mistaken it's been a few years
  Pat
rich69rs
  • LF7/M35/Z22/Z87
« Reply #2 on: February 06, 2008, 10:35:51 PM »
Current (February) issue of Hemmings Motor News, page  52, an article entitled:  "At High Cruise"  - how speed became a set and forget matter.
Discusses development of cruise control by Ralph R. Tetor the founder of Perfect Circle who manufactured amongst other things piston rings and one of GM's first cruise control systems - which was basically a mechanical system with a few electrical components.  Car in the article with the GM Speed and Cruise Control is a 1962 Chevy Biscayne with a small block.  A control knob with "low" and "high" settings was mounted on the dash.
Richard Thomas
1969 RS
« Reply #3 on: February 07, 2008, 12:22:46 AM »
Steve -
I used to work at a Buick dealership.  This option was available in 1974 on the Electra and LeSabre (maybe other years and models too?).  Anyway, I do remember the switch was dash mounted.  Good luck!     :)
« Reply #4 on: February 07, 2008, 12:32:22 AM »
Steve -
I just did a quick search and found the switch I mentioned above on Ebay...
http://cgi.ebay.com/ebaymotors/1974-RIVIERA-LESABRE-ELECTRA-BUICK-PULSE-WIPER-SWITCH_W0QQitemZ350020756979QQcmdZViewItem?hash=item350020756979
It appears from the listing this switch was also available on the '74 Riviera if your looking for it in junkyards.
L78 steve
« Reply #5 on: February 13, 2008, 02:24:31 PM »
Try Chevy and GMC trucks.Make sure to snatch the controller also.
69 Z/28 Dover White. SOLD
hotrod68
  • almost finished
« Reply #6 on: February 16, 2008, 03:45:49 AM »
If ya want to go aftermarket, J.C. Whitney sells them.
z-villejw
« Reply #7 on: February 17, 2008, 05:14:30 PM »
Could you use a headlight switch to run it? Wire it so when you pull it out, it turns on & use the dome light reastat to control the speed.
J. Wiles  Southeastern Ohio
1968 RS SS Coupe with 1967 427-435 Tri-power
Tripoli Turquoise with Black Vinyl Top
4 Speed with 3:31 12 bolt
JKZ27
« Reply #8 on: February 29, 2008, 06:06:33 PM »
Second gen Camaros (79 and later for sure) use a dash mounted delay wiper switch.
John
68 RS Ash/Ivy Gold 327EFI M20
crustyz11
My wifes 81 Z28 and my 81 Elcamio had the delay wipers with the slide knob that twisted for speed control. Look in a Original Parts Group catalogue
HOPEFUL GRADUATE FROM THE SCHOOL OF HARD KNOCKS!!
