CRG Discussion Forum
Welcome, Guest. Please login or register.
Did you miss your activation email?
May 22, 2013, 02:11:21 PM
Search:     Advanced search
Forum registration problems: Make sure you enter your email correctly and you check your spam box first. *Then* email KurtS2@gmail for help.
82137 Posts in 10495 Topics by 4347 Members
Latest Member: partsken
* Home Help Search Login Register
+  CRG Discussion Forum
|-+  Camaro Research Group Discussion
| |-+  Mild Modifications
| | |-+  Can anyone think of a GM delay wiper switch NOT on the steering column?
« previous next »
Pages: [1] Print
Author Topic: Can anyone think of a GM delay wiper switch NOT on the steering column?  (Read 3715 times)
sdkar
Hero Member
View Profile Email
« on: February 05, 2008, 01:18:44 PM »
He guys,
I am trying to upgrade to delay wipers on my 69 Camaro by using a 4th gen Camaro wiper motor.  However, as you all know, it is extremely common that GM put the delay controls on the turn signal.  Can anyone think of and suggest a vehicle that has delay wipers but uses a conventional switch that can be installed on the dash.  I am going to visit my local junkyards and see what I can find.  If anyone has an idea, let me know.  If we can figure this out together I will be happy to share the completed innovation steps for the upgrade.  So far I have the motor and the harness from a 4th gen at a cost of $15 for everything.  If I can find a switch that will work than I am sure I can configure a delay wiper system that we can all have for under $20.
Logged
red69
Member
View Profile Email
« Reply #1 on: February 06, 2008, 10:59:31 AM »
I'm just going from memory here, but I think an early around 75 Monte Carlo"s and probably others of that vintage had a dash switch. I believe it had a slide control with a twist knod to control delay. Could be mistaken it's been a few years
  Pat
Logged
rich69rs
Hero Member
Hot August Nights 2010
View Profile Email
« Reply #2 on: February 06, 2008, 05:35:51 PM »
Current (February) issue of Hemmings Motor News, page  52, an article entitled:  "At High Cruise"  - how speed became a set and forget matter.
Discusses development of cruise control by Ralph R. Tetor the founder of Perfect Circle who manufactured amongst other things piston rings and one of GM's first cruise control systems - which was basically a mechanical system with a few electrical components.  Car in the article with the GM Speed and Cruise Control is a 1962 Chevy Biscayne with a small block.  A control knob with "low" and "high" settings was mounted on the dash.
Logged
Richard Thomas
1969 RS
LF7/M35/Z22/Z87
Hero Member
View Profile
« Reply #3 on: February 06, 2008, 07:22:46 PM »
Steve -
I used to work at a Buick dealership.  This option was available in 1974 on the Electra and LeSabre (maybe other years and models too?).  Anyway, I do remember the switch was dash mounted.  Good luck!     Smiley
Logged
Hero Member
View Profile
« Reply #4 on: February 06, 2008, 07:32:22 PM »
Steve -
I just did a quick search and found the switch I mentioned above on Ebay...
http://cgi.ebay.com/ebaymotors/1974-RIVIERA-LESABRE-ELECTRA-BUICK-PULSE-WIPER-SWITCH_W0QQitemZ350020756979QQcmdZViewItem?hash=item350020756979
It appears from the listing this switch was also available on the '74 Riviera if your looking for it in junkyards.
Logged
L78 steve
Member
View Profile Email
« Reply #5 on: February 13, 2008, 09:24:31 AM »
Try Chevy and GMC trucks.Make sure to snatch the controller also.
Logged
69 Z/28 Dover White X33,ZL2,PS,M20,Std.int.04C
hotrod68
Member
rusticman48@aol
View Profile Email
« Reply #6 on: February 15, 2008, 10:45:49 PM »
If ya want to go aftermarket, J.C. Whitney sells them.
Logged
HotRod'68  1968 coupe undergoing frame-off resto/rod. 406/350/4.11s
z-villejw
Member
View Profile Email
« Reply #7 on: February 17, 2008, 12:14:30 PM »
Could you use a headlight switch to run it? Wire it so when you pull it out, it turns on & use the dome light reastat to control the speed.
Logged
J. Wiles  Southeastern Ohio
1968 RS SS Coupe with 1967 427-435 Tri-power
Tripoli Turquoise with Black Vinyl Top
4 Speed with 3:31 12 bolt
JKZ27
Member
View Profile Email
« Reply #8 on: February 29, 2008, 01:06:33 PM »
Second gen Camaros (79 and later for sure) use a dash mounted delay wiper switch.
Logged
crustyz11
Newbie
View Profile Email
« Reply #9 on: March 27, 2008, 10:56:26 PM »
My wifes 81 Z28 and my 81 Elcamio had the delay wipers with the slide knob that twisted for speed control. Look in a Original Parts Group catalogue
Logged
HOPEFUL GRADUATE FROM THE SCHOOL OF HARD KNOCKS!!
Pages: [1] Print
« previous next »
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Page created in 0.115 seconds with 17 queries.
