Author Topic: reverse switch?  (Read 8334 times)
danimaldds
reverse switch?
« on: January 24, 2008, 05:29:37 PM »
The 69 ss I just bought has reverse lights, but no switch.. Since I'm new to camaro's I thought I'd ask. I can buy a reverse switch for dnr. but, where does it go exactly? Since I have not seen another one I have no clue. I pic would be great!.. Any thoughts??  It's a muncie m20..   Dan
Dr. Dan Mairani.  ..1969 ss 350 Lemans blue/black
L78 steve
Re: reverse switch?
« Reply #1 on: January 24, 2008, 06:36:17 PM »
The switch is on the steering column down past the Ign. Sw.If you don't have the back drive linkage hooked up you won't be able to activate the B/U switch.
69 Z/28 Dover White. SOLD
danimaldds
Re: reverse switch?
« Reply #2 on: January 24, 2008, 07:28:35 PM »
Oh boy. please explain. back drive switch. Is that the on on the tranny?  Can't seem to find one for a 69. so, if I need the switch on the tranny, then that wire goes up front then to the back?  This electric shit always plays havoc with me..I don't have the "back drive linkage"... Thanks for your help steve.  Where can I get the right stuff? do you know? sorry I'm such a noob. :-\
L78 steve
Re: reverse switch?
« Reply #3 on: January 24, 2008, 09:28:59 PM »
The back-drive rod goes from the reverse arm on the trans. to a bell crank mounted on the frame below the brake booster or master cyl.Then a rod up to the column arm.This set-up activates the B/U lamp switch and locks the trans in reverse when the key is out.If you have headers installed there's no room for this system.You can get a switch and bracket to mount at the trans to activate the B/U lamps.Hurst has a universal part for this purpose or Heartbeat City #ELC1066.Steve.
smith69z
Re: reverse switch?
« Reply #4 on: January 24, 2008, 09:33:39 PM »
The backup switch mentioned is located on a switch on the steering column under the dash. There is a slide contact that is moved when the car is shifted into reserve. This sliding is due to the lockout linkage moving the cloumn internals when the shifter moves into reverse. I am sure someone can explain this better.
This is for a 4 sp, btw.
rich69rs
  • LF7/M35/Z22/Z87
Re: reverse switch?
« Reply #5 on: January 24, 2008, 09:35:37 PM »
See attached pic.  The rod connecting to the tranny is hanging down.  No trans in the car.
Richard Thomas
1969 RS
L78 steve
Re: reverse switch?
« Reply #6 on: January 24, 2008, 10:24:40 PM »
I have an extra set-up shown in the previous picture(Auto trans.) if you want to go that route.Steve.
danimaldds
Re: reverse switch?
« Reply #7 on: January 24, 2008, 10:41:32 PM »
Steve,
That's for a 4 sp on the floor?? Can't be.. Really. I thought it would be on the trans..
L78 steve
Re: reverse switch?
« Reply #8 on: January 25, 2008, 02:33:10 PM »
All transmissions use this system ,69 up.But if your not concerned with originality you can go with the universal transmission mounted switch.
Re: reverse switch?
« Reply #9 on: January 25, 2008, 04:23:44 PM »
Steve,
It was a separate switch on the transmission through 1968 on 4-speeds, changed to the backdrive linkage arrangement shown when the new locking steering column was introduced in 1969.
danimaldds
Re: reverse switch?
« Reply #10 on: January 25, 2008, 10:27:55 PM »
Just cause I'm dumb. so, when you shift the floor shifter into reverse, The reverse rod is also attached to a rod that is connected to the steering shaft. Is this correct?? Is there a product sold that works only on the trans?  Man I'm dumb. ???
L78 steve
Re: reverse switch?
« Reply #11 on: January 26, 2008, 03:03:12 PM »
Yes,correct.And yes Hurst has a trans. mounted switch.Also buy a GM assembly manual for your Camaro,Its loaded with information.
danimaldds
Re: reverse switch?
« Reply #12 on: January 28, 2008, 03:34:08 PM »
I will get the assembly manual. So, I can use the 68 switxh on my 69. I have a pic of that. I think there was two kinds..
