Author Topic: Recommendations on how to repair carb stud  (Read 4201 times)
Flowjoe
« on: January 08, 2008, 12:41:16 AM »
I have a GM high rise Aluminum intake (3972110 - '70 LT-1) it has one bent carb stud...what is the best way to repair or replace this stud?
thanks
Jerry@CHP
Re: Recommendations on how to repair carb stud
« Reply #1 on: January 08, 2008, 12:42:22 PM »
Double nut the stud and remove it.  If there are no threads left and the stud is broken, then you'll have to use a pair of vise grips.  If it's tight, then heat will have to be used.  Good luck.
Jerry
Flowjoe
« Reply #2 on: January 08, 2008, 02:47:15 PM »
Thanks Jerry.
So it is threaded in and not pressed in?  I was afraid it was a press in and figured replacement might be as for press in rocker studs.
It has threads left so I should be able to double nut it.
« Reply #3 on: January 08, 2008, 05:04:04 PM »
Thanks Jerry.
Yup, it has ordinary 5/16"-18 threads on the manifold end of the studs.
