CRG Discussion Forum
Welcome, Guest. Please login or register.
Did you miss your activation email?
May 25, 2013, 09:26:38 PM
Search:     Advanced search
Forum registration problems: Make sure you enter your email correctly and you check your spam box first. *Then* email KurtS2@gmail for help.
82273 Posts in 10508 Topics by 4352 Members
Latest Member: NCCaprice
* Home Help Search Login Register
+  CRG Discussion Forum
|-+  Camaro Research Group Discussion
| |-+  Maintenance
| | |-+  Low Fuel Indicator Module
« previous next »
Pages: [1] Print
Author Topic: Low Fuel Indicator Module  (Read 1849 times)
pablosanchez69
Newbie
View Profile Email
« on: January 16, 2006, 09:06:49 PM »
What plugs into the low fuel indicator module in the console. It looks like it is designed to have a bulb pushed into it.
Mine has nothing in the module, and the dash light stays lit all the time regardless of fuel level. The fuel gauge works fine.
Paul Low
Logged
PACE&Z2869
Member
View Profile Email
« Reply #1 on: January 17, 2006, 11:20:10 AM »
HELLO. I ASKED THE SAME QUESTION ABOUT 2 WEEKS AGO. LOOK UNDER THE RESTORATION SECTION IN THIS FORUM.  LOOK FOR  "LOW FUEL MODULE". YOU WILL SEE MY QUESTION AND A ANSWER FROM A FELLOW MEMBER. THE SHORT ANSWER NO BULB GOES INTO THE MODULE. THE MODULE WON'T CLIP INTO THE HOLE W/ A BULB IN PLACE DUE TO THE OIL PRESSURE BELLOWS. THE MODULE TURNS ON THE LIGHT ON THE DASH WHEN TANK IS LOW.
Logged
PACE&Z2869
Pages: [1] Print
« previous next »
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Page created in 0.075 seconds with 17 queries.
