Author Topic: Breaking in a motor  (Read 33522 times)
Re: Breaking in a motor
« Reply #15 on: March 31, 2007, 04:23:51 PM »
Hate to tell you guys but I believe Rotella T has been changed. Unless you have the older style jug/quart it is now different. I have some of last years oil left but see the paint scheme has changed.  Sam ???
That's the change from the CI-4 API classification to the new CJ-4 classification, which represents a reduction in the ZDDP concentration for use with the new 2008 diesel engines which have to use catalytic converters and/or particulate traps to meet the new Tier II diesel emission regulations. The ZDDP concentration in the new CJ-4 oil is still substantially higher than it is in the "SM" passenger car spark-ignition oils, and works equally as well as the CI-4 oil in our engines.
sam
« Reply #16 on: March 31, 2007, 06:10:12 PM »
Thanks John! That makes me happy.  Sam
bob69
« Reply #17 on: April 09, 2007, 10:50:40 PM »
My 302 is breaking up arround 5000-6000 rpms and has a light knock ( only somethimes ) when under a load, Also sometimes when its ideling I hear a light knock, that stops when I pull the pcv valve. sounds like its in the valve train. Did I wipe a lobe? or what else could it be? I'm scared to drive it. Any help would be great. Thanks BOB
GaryL
  • Marilyn and me
« Reply #18 on: April 18, 2007, 12:08:20 PM »
After break in, what oil do you use?
Gary
« Reply #19 on: April 18, 2007, 10:50:18 PM »
I'd recommend one of the 15W40 CI-4 or CJ-4 diesel oils (Shell Rotella, Mobil Delvac, Chevron Delo, etc.).
GaryL
  • Marilyn and me
« Reply #20 on: April 20, 2007, 12:49:35 AM »
I just ordered a case of Rotella 10-30. 15-40 is a little thick.
Gary
fireZ
« Reply #21 on: April 23, 2007, 03:33:10 PM »
What is the EOS supplement Jerry mentions from GM. Should it be used also after breakin?
1968 Z28 LA Built
LIC # RPO Z28
sam
« Reply #22 on: April 23, 2007, 04:24:30 PM »
Does the Rotella 10W30 have the same additives as the 15W40? I thought the additives we need were only in the diesel grades. A lot of guys run 1/2 can of EOS at every oil change on the flat tappet motors. At least that is what they tell me anyhow.  Sam
« Reply #23 on: April 23, 2007, 04:47:22 PM »
EOS = Engine Oil Supplement.  It's available at any GM dealer.
No.  (I asked Jerry the same question.)   :)
« Reply #24 on: April 24, 2007, 02:58:40 AM »
ALL Rotella is diesel oil - it's available in several different weights. EOS is for break-in only; it contains several heavy additives that can clog an oil filter, which is why it's labeled specifically for break-in only.
olympic69
« Reply #25 on: April 24, 2007, 03:54:44 AM »
The (API?) grades JohnZ listed will appear on the oil jug as he listed them, if the additive package IS the same- JohnZ's quote from above:
"I'd recommend one of the 15W40 CI-4 or CJ-4 diesel oils (Shell Rotella, Mobil Delvac, Chevron Delo, etc.)."
So if you choose another viscosity, look for those listed qualifications which indicate the appropriate additiives are present.
Rob
Olympic Gold X33
"Its all crazy..."
tom
    • Discount Internet Services
« Reply #26 on: April 24, 2007, 10:43:05 AM »
I am planning to re-fire my motor for the first time after several years. Will hit the Englishtown swap this weekend and look for an old distributor to prime the motor with. Since the motor has not turned in years should I also be using the rotella?
Tom
69 X11 Z21 L14 glide
o
« Reply #27 on: April 24, 2007, 09:21:01 PM »
Tom -
I believe CJ has an old distributor for sale:
http://www.camaros.org/forum/index.php?topic=2025.msg12762;boardseen#new
tom
« Reply #28 on: April 25, 2007, 05:50:02 PM »
Another foot note, get an old distrbutor shaft and make an oil priming tool out of it.  You can install this shaft in the end of a drill motor and stick it in the engine into the oil pump.  Turn the drill on and you will build oil pressure this way.  Watch your gauge as you are doing this.  The oil pressure will come up slowly.
Jerry
Thanks, but I'm just looking for an oil primer, my dist works (or at least worked) last time fired. I was just wondering if I should use the break in oil after letting the engine sit so long.
Tom
o
Gambitt
    • My car
« Reply #29 on: April 25, 2007, 06:27:53 PM »
You can buy brand new Proform oil primers on ebay for around 10-15 dollars, plus shipping.
