Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Decoding/Numbers
decoding transmission
« previous
next »
Print
Pages: [
1
Author
Topic: decoding transmission (Read 7330 times)
dab67
Member
67 SS
on:
January 13, 2006, 12:01:28 PM »
CRG HELP!!!!!!!!!!
I have a problem that needs your help!!!!!!!!! I am looking at purchasing a powerglide that is supposed to be a 67. Problem is this, no where on the tranny pan can we find any numbers what so ever. I did find these numbers on the inside of the bell housing where the Torque conmverter is placed. B 7 4. Anyone have a clue what these numbers mean??? Is it odd not to find any numbers at all on the tranny pan? maybe this tranny had it's pan replaced, but would there not be some type of Identification for this? We scrubbed the whole pan clean and could not find anything.
dab67
Tweet
Logged
dab67
Member
67 SS
Re: decoding transmission
Reply #1 on:
January 15, 2006, 01:16:23 AM »
CRG!!!!!!!
I found some other numbers on the tranny. One set is 3486 and the other number is 164. Any ideas on what these may be?
dab67
Logged
CRG Coordinator
Reply #2 on:
January 15, 2006, 04:02:52 AM »
Don't know much about powerglides. I'll just refer you to Colvin's CBTN.
And as long as it looks right and fits, it should be fine. The pan had the trans code on it and it sounds like it was replaced.
Logged
67rs/ss396
Member
Reply #3 on:
January 18, 2006, 02:18:11 PM »
The date code for a 67 pg is stamped on the passenger side of the pan. Mine
is T 7 A 23. T=toledo pg, 7=1967, A=january, 23= day, Sometimes you have
to look real close to find the numbers
Logged
67 rs/ss L48 w/headrest org.37k
67 rs/ss L35 w/headrest project
67 rs/ss L35 w/smog org 78k
67 rs/ss L78 O-O -L201C
68 rs/vert L89
67 kemie ss
Member
Reply #4 on:
February 01, 2006, 05:29:23 AM »
I've a similar situation - no #s on my PG pan either. You may try removing the pan and checking the valve body. I've seen photos from Munroe's PG book that indicate that its date coded.
Logged
Print
Pages: [
1
« previous
next »
Decoding/Numbers
