Author Topic: suspension swap 1969  (Read 4979 times)
pcmech
« on: September 29, 2007, 07:22:18 PM »
we have a totalled 1997 z28 & were curious if anyone had info about swapping into a 1969 camaro... full suspension/brakes or just part
thank you for your time
Re: suspension swap 1969
« Reply #1 on: September 30, 2007, 05:34:48 PM »
Totally different design, smaller/weaker ring & pinion/diff; why would you want to swap that in?
Bjv69ss
« Reply #2 on: November 11, 2007, 01:51:09 PM »
If you are looking to have a better handleing and stopping car... I'd part out the wreck if you need the cash first and buy a brake up-grade and add 4 wheel discs. As for suspension there are tons of kits and parts out there.  Just changing to a 1" sway bar up front and adding a rear sway bar will make a big difference.  Poly bushings front and rear will also help.  I did the latter on my convert.  Made a huge difference!
1969 Fathom Green
SS 350 Coupe
71 Impala Sport Coupe
