Author Topic: Ported vacuum on a Holley?  (Read 24481 times)
« on: September 11, 2007, 06:15:15 PM »
For John Z or anyone that knows.  I'm running the original setup in my 68 Z.  After reading so much from John Z about the ported vacuum etc., I was wondering if the stock hookup for the dist. on a Holley is ported or not?  If it is, where do you hook up the vacuum for the dist. to get manifold vacuum?  Thanks.
Re: Ported vacuum on a Holley?
« Reply #1 on: September 12, 2007, 03:58:54 PM »
The stock connection to the distributor on a Holley 4053 is ported vacuum. The easiest way to get full manifold vacuum is to tee into the short hose from the port on the front of the baseplate to the choke pull-off diaphragm - that's manifold vacuum. On a '69, the tee is already there - it feeds manifold vacuum through a signal hose to the A.I.R. diverter valve. See photo below for my "driving" setup with the hose in place from the tee to the distributor, and a rubber cap on the end of the stock pipe to the distributor.
« Reply #2 on: September 13, 2007, 03:43:16 AM »
Thanks again, I just set mine up like that.   I do have only about 10 " vacuum so I'm going to look at a different can for the dist.  BTW excellent article you wrote, I wish everyone could read something like that.  I'm even going to "convert" my rabbit to this full vacuum treatment.
sebastien
« Reply #3 on: September 13, 2007, 05:49:09 AM »
So in most applications manifold vacuum is the most suitable for distributor advance?
Was it after all a bad idea when they designed the ported vacuum? ???
Sebastien 68  327 rag top
« Reply #4 on: September 13, 2007, 02:58:58 PM »
This "Timing 101" paper explains ignition timing, centrifugal, and vacuum advance, along with the "ported vacuum" aberration.  :)
                                            TIMING AND VACUUM ADVANCE 101
                                                           John Hinckley
The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency.
The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation.
At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph).
When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean.
The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic.
Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it.
If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more.
What about the Harry high-school non-vacuum advance polished billet "whizbang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone.
Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren’t fully-deployed until they see about 15” Hg. Manifold vacuum, so those cans don’t work very well on a modified engine; with less than 15” Hg. at a rough idle, the stock can will “dither” in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15” Hg. of vacuum at idle need a vacuum advance can that’s fully-deployed at least 1”, preferably 2” of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8” of vacuum, so there is no variation in idle timing even with a stout cam.
For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it – they don’t understand it, they're on commission, and they want to sell "race car" parts.
jdv69z
  • 69 RS Z/28 52E
« Reply #5 on: September 14, 2007, 02:08:53 AM »
Thanks John Z for the info. My Z idles 10-12 in Hg so I'm not sure what vacuum advance can I have. I replaced it years ago with Echlin part which was supposed to be correct for my car, so it may be the VC-1810, but I'm going to pick up another one and test it to see. The car does idle fine now, although at a higher rpm (1000-1100)  than the 900 the factory manual calls for. It always seem to rough when I tried to set it that low. Maybe this why?
Jimmy V.
Jimmy V.
« Reply #6 on: September 17, 2007, 02:45:49 AM »
BTW the Echlin can 1810 is scarce in these parts.  Closest to OR was VA.  I was told they don't sell too many as everything is becoming electronic.  Also, I hooked my VW up to manifold vacuum and what a difference!  Smooth, responsive, lower temp and more mpgs.  I wish I had known about this earlier.  Thanks again John Z.  PS, when I was trying to ask other parts places if they had a vacuum can that would work on lower vacuum than stock, you wouldn't believe how many people told me you don't need it, just use mechanical.  Yeah, right.
« Reply #7 on: September 17, 2007, 03:25:45 AM »
John, For us 'Medium' (Hyd Lifters) performance motor guys that are utilizing the quadrajet 4MV.
Would  a 'drive setup' be obtained by "T"ing off the hose that goes from the front of the carb [Manifold-vacumm] port to the A.I.R diverter valve?
Vice as delivered Vac advance hose routing to the tube on the passanger side of the carb by the choke mech.
Reference: Page 47 of HPBooks Rochester Carburetors by Doug Roe.
I will soon be installing my #'s matching Dist Jerry' reworked for me and will set it up with the above drive configuration and enjoy the benefits others have described.
« Reply #8 on: September 17, 2007, 07:05:32 PM »
I'm not familiar with Q-Jets - have never had one or worked on one; however, the line to the choke pull-off and the line to the diverter valve should be manifold vacuum, and checking the existing ports with a vacuum gauge will tell you whether they're manifold vacuum or "ported".
