Author Topic: 12 bolt decoding information  (Read 11328 times)
jettecher
« on: October 19, 2005, 06:02:26 AM »
This is a great site. Thank you for the forum.
I am restroing a 1969 Camaro Pace car. I know this differentila is incorrect for this car, but would like to understand it's application. I have a 1969 Camaro 12 bolt differential that is coded PO 0702G and the date code is F 11 9. What is the application here? I have research material that shows 1967-8 Camaros used these codes. My research shows this is Positraction [2.56 ratio] with Metallic brakes and Large ring gear. I cannot find a reference for a 1969 Camaro having this installation. I am puzzled by the build date [1969].
jettecher
jettecher
Re: 12 bolt decoding information; Correction this is a 10 bolt rearend
« Reply #1 on: October 19, 2005, 06:28:24 AM »
« Last Edit: October 19, 2005, 11:22:03 AM by 67ss350camaro »
67ss350camaro
« Reply #2 on: October 19, 2005, 11:22:38 AM »
It's a 3.08 non-posi 10 bolt for 69.
67 RS/SS 350 auto (owned since 81.)
97 V6 5-speed Coupe (work car ordered new)
2012 1LS (V6 6-speed) Coupe (new work car)
My Camaro
ccargo
« Reply #3 on: October 20, 2005, 03:34:56 AM »
The assembly date is too late for a IPC as well. I know of a 69 LOS 396 IPC out of TN. that had the 12 bolt stolen and replaced with a 10 bolt while being serviced. Is this the car?
67 O-1 O4A L35 Convertible, Indy Zone IPC
jettecher
« Reply #4 on: October 20, 2005, 06:40:46 AM »
Thanks for your reply.
jettecher
« Reply #5 on: October 27, 2005, 12:03:41 AM »
I don't think this is the car, but I wouldn't know. This car has been off the road for 12 to 14 years. I have three different sources for differntial data and none show a PO code for 1969. What reference book are you using/ I have the GM parts book for these years also.
