Author Topic: Front fender emblems  (Read 3081 times)
dab67
  • 67 SS
« on: August 05, 2007, 08:57:24 PM »
Is there anyway other than pulling the inner fenders or wheel wells off to attach the double flags and engine emblem (350)to the rear of the front fenders? I lost a double flag and a "350" emblem on the drivers side front fender. Not sure if the speed nuts came off on the inside of if there were any there in the first place. The replacements I got have larger size tabs than the holes in the fender. The emblems came with speed nuts. Any other solution or do I have to pull the inner fenders off?
Dave
67camarorsss
Re: Front fender emblems
« Reply #1 on: August 09, 2007, 10:14:28 PM »
Not exactly original but I believe that barrel nuts will work. They press into the hole the emblem pins go thru. They (the barrel nut) have barbs on the inside that will grab the emblem pin as you press it in.
- 1967 RS/SS 396/TH400 (loaded clone restification)
- 1998 Z28 LS1/M6 (daily driver)
- 2002 Z28 LS1/4L60E (12 sec toy/bookend to the 67)
