Is it possible for an LM1 to come with a cowl induction hood and front and rear spoilers from factory? Also did Dealers ever install the cowl induction hoods? What kinda of primed did the fractory use? Two other questions, how can you tell if a car had single or dual exhaust and how clean is the cut for the hole for a four speed shifter made by the factory.
I have a two inch hole below the wiper motor almost directly behind the valve cover on the driverside and there is a hole in the tunnel that is very clean on three side and looks like the metal was folded over. The car has the dash and colume setup for colume shift and it has the plate for a 3 speed which looks all to be orignnal.
this is the cowl tag: st6912437nor195236bdy
tr727 12b 71e pnt
x44
