Author Topic: drive train  (Read 9048 times)
69 ss hugger
drive train
« on: December 28, 2005, 10:00:11 PM »
Heres all the info from my car:
Vin:124379N562385
ST6912437 NOR 208374 BDY
TR 711 72 72 PNT
12B X11
Motor:9N562385T1207HB
Trans:19N562385 Pan:Y9 S 29D
Rear End: BP1215 2 cant tell whats in between the 5 and 2 if any. 10 bolt non posi 2:73
Re: drive train
« Reply #1 on: December 29, 2005, 04:05:39 AM »
Thanks!
I still don't understand the 10 bolt in it. Unusual since all other L48/M38 cars have a 12 bolt.
Or it got swapped and the date happened to be perfect for the car, which I kinda doubt.
JKZ27
Re: drive train
« Reply #2 on: December 31, 2005, 07:28:48 PM »
Does that axle date seem a bit late for the car? I compared it to my 12B car #5583xx.
Engine:TII29HA
Axle: BS1121G 2
           E
Ofcourse, thats assuming mine is original. :P
For comparison
John
John
68 RS Ash/Ivy Gold 327EFI M20
fiveforty
Re: drive train
« Reply #3 on: January 03, 2006, 04:34:19 AM »
How can a rear end that was built on Dec 15th go into a car that was built the 2nd week of Dec?
Tinkerr
Re: drive train
« Reply #4 on: January 03, 2006, 06:44:22 AM »
fiveforty
i don't know where you got your info,but mines says BS=69 3:31 posi 1121=11th month 21=21st day G=gear assembly plant 2=second shift E=eaton posi
fiveforty
Re: drive train
« Reply #5 on: January 03, 2006, 12:38:38 PM »
I was asking about 69 ss huggers. The first post in this topic that is where I got my info from.
Re: drive train
« Reply #6 on: January 03, 2006, 04:47:21 PM »
It would have been possible for a 12B body to show up on the Chevrolet side of the plant as late as December 18th, so a December 15th axle isn't out of the question. 12B is the week when the raw body started in the Body Shop at Fisher Body, not when the car was produced at Chevrolet.  :)
Re: drive train
« Reply #7 on: January 04, 2006, 02:15:52 AM »
It is very late for that car. He originally posted on camaros.net.
My response was:
That axle date is *really* close. So close that I'd say it's possible that it's original. If so, it's the only exception I've seen in 69.
GM docs do indicate that all 69 L48 autos were to get 10 bolts, but that's not what happened.
69 ss hugger
Re: drive train
« Reply #8 on: January 04, 2006, 04:45:00 AM »
I dont know 2 many people that would keep a car all together,and get rid of a 12bolt and replace it with a 10bolt.
69 ss hugger
Re: drive train
« Reply #9 on: January 04, 2006, 05:55:26 AM »
If u dont think it right.What do u think it should have? What do u think the date code should B? and a 12bolt with what gears did they run? Can u find these 4 sale?I would rather have a 12bolt.  THANKS MIKE
Re: drive train
« Reply #10 on: January 04, 2006, 07:36:25 PM »
And replace it with a 10 bolt that is perfectly dated.
Reread my posts. I believe it probably is original.
An SS auto would have 3.07 gears as standard. 2.73 would be the economy gear.
69 ss hugger
Re: drive train
« Reply #11 on: January 04, 2006, 08:09:41 PM »
Sould it b a posi?And what would u do if it was your car leave the 10bolt in it?I see u guys call it a L48 car what does that mean?I THANK ALL OF U FOR THE HELP  MIKE.
Re: drive train
« Reply #12 on: January 05, 2006, 04:14:58 AM »
Posi was an option.
I'd leave it.
L48 = 350/300 hp engine
69 ss hugger
Re: drive train
« Reply #13 on: January 06, 2006, 02:28:17 AM »
Thanks for the help kurt i app. it MIKE.
cib12
Re: drive train
« Reply #14 on: January 16, 2007, 02:47:16 AM »
guess i need to check my car-(pre x code-marked X 1) rs- ss350 air cond- it has a 10 bolt pos- i just assumed it had been swaped out- especially even 30 years ago it was a lot harder to find  a 12 bolt pos and if you did it was more money-- 12 bolt from a junk yard( if i can remember) seemed to run 250- 500 and at the time a 10 bolt could be bought for as little as a 100-150- and most yards did not even look if it was pos track
