Author Topic: Big Block Motor Mounts  (Read 4661 times)
ss68396
« on: June 18, 2007, 05:31:40 PM »
Hey guys,
Im having a hard time finding a set of Polyurathane Motor Mounts for my 68' BB. Do you guys have any ideas or suggestions where a guy can pick some up. I have already ordered the Hyper-Flex kit from energy to redo all the factory bushings so far.
Any help would be very appreciated.
Also would you guys say a solid mount is better vs. the rubber mounts for my application. 454 approx. 300hp with 4 speed
Jay
« Last Edit: June 19, 2007, 03:39:45 PM by ss68396 »
Re: Big Block Motor Mounts
« Reply #1 on: June 20, 2007, 06:40:15 PM »
BB's used the same engine-side mounts as the 350 and 302. Solid mounts will shake the fillings out of your teeth.
ss68396
« Reply #2 on: June 20, 2007, 09:32:55 PM »
Thanks alot John.
sd1968z28
« Reply #3 on: June 26, 2007, 03:29:10 PM »
go  to your local chevrolet dealer and get the facory mounts, i beleive they are still avaliable and will work fine and fit perfect.
