Author Topic: torque sequence  (Read 6496 times)
sebastien
torque sequence
« on: May 21, 2007, 01:28:55 AM »
what is the proper torque and sequence for a small block cast iron intake manifold and original exhaust manifolds?
also,is that correct that there is no gasket betwwen the heads and the exhaust manifolds?
Sebastien 68  327 rag top
dab67
  • 67 SS
Re: torque sequence
« Reply #1 on: May 21, 2007, 10:21:09 AM »
Sebastien:
Let's see if this comes out correctly. Sequence for SBC Intake. I have nothing on the exhaust.
Dave
dab67
  • 67 SS
Re: torque sequence
« Reply #2 on: May 21, 2007, 10:27:14 AM »
Sorry it will not load, wrong format,
Looking at engine from front
Right Side(Passenger) sequence numbers are  12,11,4,1,5,and 6 for the very back
Left side(Drivers) sequence nmbers are 10,9,3,2,7 and 8 for the very back
30 pounds torque with oil.
Hope this helps
Dave
Re: torque sequence
« Reply #3 on: May 21, 2007, 04:50:54 PM »
Sebastein -
All this info is in the factory Chassis Service Manual & Chassis Overhaul Manual, which can be purchased at most first generation Camaro part retailers.   :)
sebastien
Re: torque sequence
« Reply #4 on: May 21, 2007, 07:59:07 PM »
ok thanks,I have the chassis manual.iI'll double check.
Re: torque sequence
« Reply #5 on: May 22, 2007, 02:59:51 PM »
Correct - no Chevy V-8 ever used exhaust manifold gaskets, although the aftermarket gasket manufacturers seem compelled to include them with their gasket kits.
