Author Topic: Engine restoration and improve performance  (Read 10136 times)
emanuelK
Re: Engine restoration and improve performance
« Reply #15 on: June 18, 2007, 03:11:23 AM »
It is stamped on the end. Perhaps there shall be another marking to look for??
« Reply #16 on: June 18, 2007, 01:59:57 PM »
Most aftermarket cams are stamped on the ends; original GM cams have a raised casting number and other raised casting symbols cast into the shaft between the lobes, with no stampings on the ends.
emanuelK
« Reply #17 on: June 19, 2007, 10:53:50 PM »
Engine is up and running. I started to break in the new cam and noticed the response to thrust is much different (better) than before. So far so good. The vaccuum is also much higher, I can tell by using the power brake at idle. I drove the car up to 60-70 mph and the performance is absolutly better. I still waiting for my new headers to arrive and expect some more can be done.
Unfortunatly I have problems with my starter - se topic under maintainance.
Thanks all for you're support. /Emanuel
