Author Topic: brake pedal pressure difference 68 to 69?  (Read 918 times)
WaltZ
« on: April 23, 2025, 05:04:33 PM »
my 69 z needs a nice easy pressure on the pedal to stop,
whereas my 68 z requires noticeably more pedal pressure.
while I was having the original 68 power booster restored, I was running an aftermarket which allowed for less brake pedal pressure to stop.
but now with the rebuilt oe, it's quite stiff.
all lines good and no leaks, booster holds vacuum for days.
could the different pedal pressures between the 68 and 69 just be the nature of the beasts.
Thanks in Advance.
Re: brake pedal pressure difference 68 to 69?
« Reply #1 on: April 23, 2025, 09:09:43 PM »
Clevis in the lower hole?
GMAD_Van Nuys
« Reply #2 on: April 24, 2025, 03:28:45 PM »
Previous CRG discussion about pedal pressure on 1968 Camaro:
http://www.camaros.org/forum/index.php?topic=15720.0
