Author Topic: 1968 Z28 intake  (Read 1222 times)
Rustynut
1968 Z28 intake
« on: February 19, 2025, 09:33:13 PM »
Is there a way to tell if this intake belongs to a 67-68 Z28?
boomer632
Re: 1968 Z28 intake
« Reply #1 on: February 19, 2025, 10:15:17 PM »
Neither, looks to be a  GM performance catalog intake. Not assembly line Winters Foundry piece.
06A X66 711 57 57 L78 M22 BU
GMAD_Van Nuys
Re: 1968 Z28 intake
« Reply #2 on: February 19, 2025, 10:30:02 PM »
The intake manifold in 1967 & 1968 also had the oil fill tube on the intake as shown in the photo below:
http://www.camaros.org/forum/index.php?topic=20919.0
Stingr69
Re: 1968 Z28 intake
« Reply #3 on: February 24, 2025, 01:59:18 PM »
I think that manifold is much later.  Could have come from a GM crate motor.  The squared off port exits give it away at a glance. Assy line intakes were plain.
 It has the centraly located thermostat housing so it would work for a '69.  Earlier Z/28 manifolds had an offset thermostat location that would not line of with the long water pump style '69 alternator bracket.
rocco376
Re: 1968 Z28 intake
« Reply #4 on: February 24, 2025, 02:20:08 PM »
Chevy Bowtie Z28 Replacement Aluminum Intake SBC 10185024
dutch
  • Documented Canadian 1968 Z/28
Re: 1968 Z28 intake
« Reply #5 on: February 24, 2025, 10:09:15 PM »
If it was the real thing - my understanding is that the only way would be to remove the splash plate on the bottom side and get the date casting number off of it..
Otherwise as far as I know the real '67 and '68 versions of the 610's are virtually identical otherwise.
Big difference in the runner shape between the one shown and again any '610 version - plus as mentioned, the bowtie emblem and a lack of oil fill tube hole on the front as well!
David K
  • Dr. Longblock
Re: 1968 Z28 intake
« Reply #6 on: March 15, 2025, 11:19:06 PM »
Genuine intakes did not have a bow tie cast into it, among also missing the front oil filler tube.
