Author Topic: Adjust Steering  (Read 1033 times)
DuWayne Ladner
Adjust Steering
« on: February 26, 2024, 06:55:47 PM »
Have a lot of play in steering wheel. Manual steering. Car is SS396 L78. Do I loosen the nut on steering box and add to adjustment. Any help would greatly be appreciate. Car was contracted out on the restoration, but I done the cleaning up of steering box and can’t remember if I messed with the adjustment or not. Thanks!
GMAD_Van Nuys
Re: Adjust Steering
« Reply #1 on: February 26, 2024, 08:05:34 PM »
Section 9-37 of the GM chassis manual says it is not recommended to try and adjust the steering box when it is installed in the vehicle:
https://www.midweststeering.com/wp-content/uploads/Saginaw-800-PS-Comp.pdf
JohnZ made a prior comment about adjusting the steering box:
http://www.camaros.org/forum/index.php?topic=3881.0
R68GTO
Re: Adjust Steering
« Reply #2 on: February 27, 2024, 11:50:19 PM »
I rebuilt my manual steering box and adjusted it out of the car to get it close then made small final adjustment after re-install.  It's really important to get it "centered" in the travel.
Out of the car the force required to rotate the input should noticeably get higher when you approach the center of travel, with the highest resistance at dead center of travel.  Once back in the car, I loosed the nut and adjusted the bolt just slightly to stiffen it up to my liking.  Since you're not sure how it got loose, I would pull it and try to reset it on the bench, then re-install and see if it got better. There are some good Youtube videos on rebuilding and setting these Saginaw units.
1969 427 COPO Camaro Lemans Blue/Black, M22 4 speed, 15,500 original miles
DuWayne Ladner
Re: Adjust Steering
« Reply #3 on: February 28, 2024, 02:56:41 PM »
Thanks, R68GTO. To avoid damage to the unit, and total removal from steering sector, can it be broke loose at the rag joint and drop steer shaft and try to adjust. A little out of my ability, or just return it to my restorer, or my ace mechanic. Appreciate the info.
boomer632
Re: Adjust Steering
« Reply #4 on: February 28, 2024, 06:34:48 PM »
I am in the middle of a manual steering thingy myself and was looking on YT for videos. I came across one for the 5679142 box. Any links you could PM me or post?
69 SS NOR 06A 711 57 57 X66 L78 M22 BU
R68GTO
Re: Adjust Steering
« Reply #5 on: February 28, 2024, 11:51:59 PM »
I can't find the specific one back that I used, but I do recall it wasn't the exact box I had.  Saginaw's design, rebuild, adjustment for manual boxes were similar across multiple applications.
GMAD_Van Nuys
Re: Adjust Steering
« Reply #6 on: February 29, 2024, 01:15:43 AM »
A Saginaw manual steering box is also used in early Mustangs and in the Hot Rod article below, it is noted that you can adjust the box by loosening the nut on the box and tightening the bolt (sector screw) until it is snug as R68GTO described:
https://www.motortrend.com/features/steerage-class-september-1987-982-1300-86-1/
If there is no change as a result of the adjustment, it is recommended that the steering box needs to be rebuilt.
Re: Adjust Steering
« Reply #7 on: March 06, 2024, 03:03:20 AM »
It's more than that.
As JohnZ said: Manual steering gear adjustment is covered in Section 9 of the Chassis Service Manual. You can do serious damage to some very expen$ive steering gear parts by "adjusting" it without following the procedure in the manual.
Kelley W King
Re: Adjust Steering
« Reply #8 on: March 06, 2024, 12:58:21 PM »
I did the snug the screw on my manual steering box on my 64 vette years ago. Did not help the situation. Ended up replacing the box.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
DuWayne Ladner
Re: Adjust Steering
« Reply #9 on: March 06, 2024, 03:46:22 PM »
Thanks, everyone for responding. Now a dummy question, being an old fart, where can I find a chassis service manual to read up on Section 9 for adjusting, and is this some that can be done by dropping the steering sector at rag joint? Just a thought. Thanks.
David K
  • Dr. Longblock
Re: Adjust Steering
« Reply #10 on: March 06, 2024, 10:47:17 PM »
Literally just type it in your browser....everyone sells them.
68 Ragtop
Re: Adjust Steering
« Reply #11 on: March 07, 2024, 12:24:30 AM »
Just because I like you, I am going to give you section 9 for free.
All you have to do is click this link that was previously provided:
You can save it to your computer, print it out, or just know is here to refer too.
boomer632
Re: Adjust Steering
« Reply #12 on: March 07, 2024, 12:15:23 PM »
I assume the adjustment in Sect 9 applies to manual boxes too no?
DuWayne Ladner
Re: Adjust Steering
« Reply #13 on: March 07, 2024, 06:19:44 PM »
Thank you so much 68 Ragtop, but I’m like boomer632, is this for manual steering? Will wait to hear from you, before I print this! Thanks again.
68 Ragtop
Re: Adjust Steering
« Reply #14 on: March 08, 2024, 03:31:42 PM »
If you are talking about the "over center" adjustment, I believe it's the same. I checked my 1968 chassis service manual and the procedure is similar for vehicles with "regular" steering and the diagrams show a manual box. The procedure for adjusting the worm gear actually looks quite simple, unless you have a tilt column or simulated wood wheel. You don't even have to take the box out for this adjustment in 1968. Just disconnect the pitman arm and measure with a torque wrench.
