Author Topic: 1967 caliper hardware finishes  (Read 387 times)
CantRepeat
« on: February 22, 2024, 03:28:36 PM »
What are the correct finishes for these parts?
Rod that holds the brake pads to the caliper
The bolts that bolt the caliper halves together
The brackets that bolt to the caliper the hoses mount to
Thanks for the help, again.
« Last Edit: February 22, 2024, 04:02:34 PM by CantRepeat »
-Tim
67 RS/SS Vert C-1 797-Z LOS 11B
EXDL 2EMGR 3SL
4P
Re: 1967 caliper hard finishs
« Reply #1 on: February 22, 2024, 03:59:20 PM »
Here is a 1967 Disc Assy removed in 1980's and stored in preservative
Photos 3 each
CantRepeat
Re: 1967 caliper hardware finishes
« Reply #2 on: February 22, 2024, 04:05:01 PM »
Thanks for the photos.
Kind of hard to make out the finishes.
Bracket looks phosphate of some kind. The bolts possibly too.
Is the caliper yellow?
-Tim
EXDL 2EMGR 3SL
4P
« Reply #3 on: February 22, 2024, 04:13:39 PM »
The Yellow, Orange and Green & White are inspection Dab's of paint indicating quality or inspection attributes.
Pacecar
« Reply #4 on: February 24, 2024, 09:41:39 PM »
This is from the 1967/1968 Camaro Legends Judging Manual. Did not copy photos but the photos are in the Manual
Calipers are painted semi-gloss black.  All machined surfaces on the calipers will be unpainted natural metal. The calipers for 1967 and 1968 are a 4 piston design and carry a casting number of 5455533 on the outer half and 5455530 on the inner half.  There are two different brake line sizes found on the calipers. It is believed that the early 1967 used a 3/8 inch hex flare nut on the caliper for both right and left. The later 1967 and all 1968 used the 7/16 inch hex flare nut on the left side caliper and a ½ inch hex flare nut on the right side caliper. All of the mentioned lines use a 3/8 inch hex flare nut for the hose end of the spring wound steel line that connects the two together. The caliper is mounted using two 7/16 inch coarse thread black finish hex head bolts and lock washers. With the upper bolt retaining the semi-gloss black painted special bracket to secure the hose using a black “U” clip. The bleeder valve is silver zinc/cad plated and does not use any type of cap. The caliper brackets are yellow cad/zinc plated and numbered 3913798R and 3913797L.
CantRepeat
« Reply #5 on: February 25, 2024, 02:06:57 PM »
Thanks for posting this. So as far as I can make out:
Rod that holds the brake pads to the caliper - still unknown phosphate. I suspect it's either yellow cad, zinc, or phosphate (yeah, I know that's about all of them) edit - just found a nice photo of Chick's 68 brakes and this rod is phosphate.
https://www.camaros.net/threads/time-for-another-68-z-28-to-be-restored.182584/page-22#post-1668891
The bolts that bolt the caliper halves together - top one is semi gloss black, I assume same as the paint on the calipers
The bracket that bolts to the caliper the brake hose mounts to with the spring clip - it says the semi gloss black
The bolts that hold the caliper to the yellow cad brackets - are black finish, is that black paint or magnesium phosphate black?
I looked at Chick's 68 restoration photos, but of the caliper mounting hardware finishes are tough to make out.
« Last Edit: February 25, 2024, 03:25:47 PM by CantRepeat »
-Tim
EXDL 2EMGR 3SL
4P
