Welcome to the CRG Discussion Forum!Classified ads are not allowed on the forum.
Backup lights
Ron,Replace those ground straps and screws too!Jerry im slow in getting the new pics on here,yes new straps are on and engine is in the car. JM
im guessing there is a wire that connects to this plug and goes to a switch on the trans somewhere? Anyone know where i can get this wire and switch? anyone have a pic of the routing of the wire?
Ron,Replace those ground straps and screws too!JM
John,The back-up plug in the firewall is a 67 and 68 thing. The plug in the firewall mates with a wiring harness that plugs into it, and the other end goes to a bracket and switch mounted on the transmission side cover. The switch is part of the harness.Jerry
Quote from: Jerry@CHP on May 06, 2007, 01:10:20 PMRon,Replace those ground straps and screws too!JMJerry -Why? What's your thinking behind this? Where do you buy replacement ground straps and screws?Paul
ron. the hole next to the wiper motor is the hole for the oil pressure line. my 67 rs/ss doesnt have a rubber grommet. the fitting is held in with a nut on the engine side.
All of these components are available through Rick's First Gen.JM
