Author Topic: Correct Carb 69 396 325hp  (Read 11723 times)
Ejam
« on: May 05, 2007, 09:49:32 PM »
l have a 69 ss 396 325 hp that came with a quadrajet but the original carb is not with it. Does anyone know the correct carb number and a date? My guess is 7029200 but not sure of the date. The engine build date is T0416JG. Thank you Earl
Re: Correct Carb 69 396 325hp
« Reply #1 on: May 05, 2007, 10:24:44 PM »
Earl -
Good guess!  7029200 is the correct carburetor for the '69 Camaro 396-325 hp (L35) engine with the TH400 transmission.  The carburetor was installed at the car assembly plant, so it should be dated from about ten days to a month or two prior to the car's final assembly date.
Ejam
« Reply #2 on: May 06, 2007, 02:58:12 PM »
as far as date code on the carb. can you give a range that might have been good for my ar/motor? l'm not sure if Jan 1 was day one..... 1009? etc....
« Reply #3 on: May 07, 2007, 03:45:09 AM »
What's the build date of your car?
Ejam
« Reply #4 on: May 07, 2007, 08:05:40 PM »
04C
« Reply #5 on: May 07, 2007, 08:35:22 PM »
04C
Earl -
Any carburetor with a date code in the 02C - 04A range should be satisfactory.  Everyone agree?   :)
Ejam
« Reply #6 on: May 07, 2007, 08:44:13 PM »
ok so can you give me an example of the number/date that l might see on the carb?  they are 4 digit numbers l believe?
« Reply #7 on: May 07, 2007, 09:13:46 PM »
Earl -
A carburetor with a date code of 0489 to 0949 (2-17-69 to 4-4-69) should be satisfactory.  Everyone agree?
Ejam
« Reply #8 on: May 07, 2007, 09:29:09 PM »
thank you very much!
« Reply #9 on: May 15, 2007, 07:43:22 PM »
Unfortunately, there's some confusion in the various references on this carb.
The correct # 7029204 FF.
The date could even be a week closer (about 1019).
Ejam
« Reply #10 on: May 16, 2007, 02:01:20 AM »
Kurt I agree that is a possibility also thanks. whats the ff stand for?
« Reply #11 on: May 16, 2007, 02:35:30 AM »
Earl -
FF is the customer code, sometimes referred to as the broadcast code.
Ejam
« Reply #12 on: May 16, 2007, 02:49:29 AM »
I am seeing the 7029204 was used more for the 350 hp motor.
« Reply #13 on: May 16, 2007, 04:07:50 AM »
Possibility? Which, the date or the carb #? The carb # is the correct one. I believe the L34 auto used the same carb, but I can't confirm it, yet.
The 7029200 is not the correct carb.
Ejam
« Reply #14 on: May 16, 2007, 11:46:15 AM »
every book l've been reading is showing the 7049200 as the carb used for the 69 L34 325 hp. what publication are you getting the 7049204 from? thanks
tim69camaro
« Reply #15 on: May 17, 2007, 01:43:13 AM »
If 7029204 is the right number the search begins again for me. I finally found a 7029200 recently. I should have asked first. Don't worry Earl, I am looking for a Nov. 1968 date so we won't be competing for the same one.
The website that referenced the carb # also had the L35 districbutor as a 1111497. Is this correct?
Tim Bailey
Steve68
« Reply #16 on: May 17, 2007, 01:51:17 AM »
Yes.
« Reply #17 on: May 18, 2007, 06:56:13 AM »
I'm not. 204 is what is actually on original cars. Never seen a 200 on an original car.
Ejam
« Reply #18 on: May 18, 2007, 06:00:57 PM »
Kurt l am not doubting you but would like to know where you seen that that was the carb for that motor.
Ejam
« Reply #19 on: May 18, 2007, 06:44:24 PM »
Click here: Carb Decode
Ejam
« Reply #20 on: May 18, 2007, 06:45:42 PM »
« Reply #21 on: May 20, 2007, 05:35:10 AM »
I'm looking in the CRG database. We have several 69 L35 cars that we have data on the the original carb. I also confirmed it via broadcast sheets.
tim69camaro
« Reply #22 on: May 22, 2007, 11:10:49 PM »
Earl, there is one listed 7029204 on ebay right now dated 0769.
Tim Bailey
Ejam
« Reply #23 on: June 01, 2007, 02:38:49 AM »
thanks tim.....l missed it  :(
beebfan
« Reply #24 on: November 07, 2007, 10:18:03 PM »
I have the same car with the build date 09A, and carb. number 7029215 .
I assume that this is the factory carb. as everything else is stock on the car.
Am I incorrect thinking this?
tim69camaro
« Reply #25 on: November 08, 2007, 12:00:35 AM »
Your car must be a 4 speed as the odd numbered last digit would indicate. If your car is 4 speed it is probably the right carb based on another website I found recently. The 7029204 is for automatic.
Tim Bailey
beebfan
« Reply #26 on: November 08, 2007, 06:48:31 PM »
Actually my car is an automatic with 77000 on the odometer.
« Reply #27 on: November 09, 2007, 03:10:15 AM »
I do not think that's the correct carb for an auto car.
nuch_ss396
« Reply #28 on: November 11, 2007, 02:16:52 AM »
L/34 is the 350hp-396.  L/35 is the 325hp-396
7029204 and 7029215 are the 396-350hp & 427-390hp carbs based on my research.
69 SS 396, Hugger Orange, D/80, D/90
Chambered Exhaust, N/66, THM400, 3:73 posi
Steve A.
« Reply #29 on: November 11, 2007, 03:40:38 AM »
For 1969, the Rochester 7029204 FF Carburetor was used on the 396/325 and the 396/350 with Automatic Transmissions.
The 7029215 EH Carburetor was used on the 396/325 and the 396/350 with Manual Transmissions.
Note that both of these differ from published listings, but CRG research has shown these applications to be correct.
Ed "Bert" Bertrand
email me!
