Author Topic: 67 RS/SS w/AC blower motor wire  (Read 710 times)
CantRepeat
« on: September 13, 2023, 04:54:34 PM »
Good day,
I've got a 67 RS/SS with AC and my question deals with blower motor wiring.
On a non AC car there is an orange wire that is part of the engine harness that runs to the blower motor. On an AC car those wires are part of AC harness.
Does the engine harness on an AC car still have the orange wire or is it omitted when the harness is built.? If they use the same harness was anything done to the orange wire to terminate it?
I've looked in the AIM and it does show the orange wire routing and UPC 12 A9 shows the non AC wiring and UPC C60 refers to E1-7 for AC cars. E1 shows the AC.
I've attached a non AC pic to show the wire in question. I am aware that the wire in the photo isn't routed correctly. :) not my car
On my AC car the orange non AC wire was cut near the starter. I believe the harness to be original to the car.
I've got an AAW replacement and it has the orange wire on it. I'm just not sure what to do with it.
-Tim
67 RS/SS Vert C-1 797-Z LOS 11B
EXDL 2EMGR 3SL
4P
CantRepeat
Re: 67 RS/SS w/AC blower motor wire
« Reply #1 on: September 16, 2023, 01:00:56 PM »
To add a little more context to my question.
I've attached few more photos.
My old engine harness that runs down to the starter has a cut orange wire that I believe would be used for the blower in a non AC car.
Likewise, the new harness has this orange wire that isn't used on AC cars and I'm not sure if the factory just terminated the wire or if there were two different harnesses used on non AC vs AC cars.
The other photos shows the wires that are used for the blower motor on AC cars and they come from a different harness.
If anyone has any suggestions, I'm open to hear them.
-Tim
EXDL 2EMGR 3SL
4P
CantRepeat
« Reply #2 on: September 18, 2023, 05:34:40 PM »
I'm beginning to think 67 AC cars would of had the heat only orange wire taped back up on the harness. No one of any authority has said this.
If anyone has a 67 factory AC survivor car and has time could you check for the orange wire that runs down to the starter and see if the wire is still there. If so, how was it handled.
Thanks for any help.
-Tim
EXDL 2EMGR 3SL
4P
GMAD_Van Nuys
« Reply #3 on: September 18, 2023, 05:54:51 PM »
There is a discussion of the orange wire on a 1967 Camaro with a/c on the website below:
https://www.camaros.net/threads/orange-wire.41053/
Petes L48
« Reply #4 on: September 18, 2023, 05:55:49 PM »
At the top of C60 E2 sheet in the AIM, at center under item #4 TAPE, there is a note B to coil and tape a production blower motor wire, to the harness.  Is that the wire you are looking at?
CantRepeat
« Reply #5 on: September 18, 2023, 06:39:08 PM »
I see that now but I have multiple questions here.
That page shows a 6cyl and the location where the orange wire comes out of the firewall is not the harness I'm talking about.
However, it would seem reasonable the same would be done on a v8 car.
-Tim
EXDL 2EMGR 3SL
4P
CantRepeat
« Reply #6 on: September 18, 2023, 06:55:33 PM »
There's a discussion about the 69 AIM and the orange wire being bundled up and taped to the AC control wires.
So, the does let me know the orange wire was on every car AC equipped or not.
I'm also being told GM cut the orange wire on 67s with AC.
I bet there are survivors out there that have it both cut and rolled and taped.
-Tim
EXDL 2EMGR 3SL
4P
