Author Topic: 9N503891 engine found  (Read 10591 times)
69z28rsbilly
« on: May 04, 2007, 04:39:00 AM »
casting date L 22 8
assembly date V0827FK
vin number 19N503891
please PM me thanks
« Last Edit: May 04, 2007, 05:03:33 AM by KurtS »
X33 72 72 RS
X33 71 71 RS
X33 10 10
Re: 19N503891 engine found
« Reply #1 on: May 04, 2007, 04:55:11 AM »
casting date L 22 8
please PM me thanks
Are you sure about the engine assembly date?  That's over 8 months after the block was cast.   :o
Re: 9N503891 engine found
« Reply #2 on: May 04, 2007, 05:09:34 AM »
I'd be interested in a pic of the engine pad. :)
No hurry.
Thanks!
69z28rsbilly
« Reply #3 on: May 04, 2007, 05:06:57 PM »
i was thinking the same thing on the assembly date.i believe i double checked.i will get some pictures as soon as possible.
the casting number is 3932386.
Kurt would this be a 2 bolt main block having the FK code?
X33 72 72 RS
X33 71 71 RS
X33 10 10
« Reply #4 on: May 07, 2007, 04:47:13 AM »
Yes, it should be a 2 bolt.
melav8r
« Reply #5 on: May 19, 2007, 09:56:25 PM »
That car is an early sept 68 built, with a late august engine assy date the L on the casting date would make more sense as a H. any chance the H was mistaken for an L?
69z28rsbilly
« Reply #6 on: June 11, 2007, 09:09:31 PM »
yes it turned out to be an "H".
sorry for all the hoopla :-[
X33 72 72 RS
X33 71 71 RS
X33 10 10
69z28rsbilly
« Reply #7 on: June 11, 2007, 09:12:44 PM »
this engine has been rained in for several months and is sitting in a old impala at a wrecking yard.
the wrecking yard wants $100.00 for it.i just dont know if its good anymore as for cylinder rust etc.
should i save this engine?
what do you guys think? :-\
X33 72 72 RS
X33 71 71 RS
X33 10 10
« Reply #8 on: June 12, 2007, 05:30:52 AM »
A hundred bucks is cheap if it's a complete engine, not cracked, standard bore and you believe you can clean it up with a slight bore.  On the other hand, FK engines (327cid/210hp) aren't rare or in high demand.  I guess it comes down to, do you need (or want) another project for the summer?  Now, if the engine assembly code had DZ at the end...    ;D
Either way, have fun and keep looking!
rich69rs
  • LF7/M35/Z22/Z87
« Reply #9 on: June 12, 2007, 10:12:01 PM »
One man's junk another man's treasure.  Wish that beast was close enough to Lake Tahoe / Carson City / Minden, NV area whare I could run over and pick it up.  Same engine that is in my '69 RS; FK = 1969 Camaro 327 w/ Powerglide.  In my years of searching the junk yards, I've only found one '69 Camaro 327 engine - the one now in my car.  I wouldn't necessarily agree that you can run down the street and find one - you would probably find that it might be easier to find a DZ block because people hang on to them.
« Last Edit: June 12, 2007, 10:15:12 PM by rich69rs »
Richard Thomas
1969 RS
