Author Topic: Accel Points Question  (Read 1077 times)
vetteskip
« on: August 13, 2023, 12:25:41 PM »
Are the two contacts on the points suppose to sit parallel to each other when out of the car? My set has a gap on one edge when closed, is this to compensate for the dwell setting when opened? The contact burns are on the outer edge, not sure if this is normal. These points have about 200 miles on them.
1969 Z28 X33D80, original drivetrain, unrestored
1968 Z28 original drivetrain
1967 Corvette L71 36k miles, unrestored
1969 Corvette 350/350 own 30 yrs
David K
  • Dr. Longblock
Re: Accel Points Question
« Reply #1 on: August 13, 2023, 03:08:38 PM »
Yes they should be making full facial contact, which when done gives you the maximum and non arcing pattern unlike the meltdown you currently have. I would get a new set although you could atttempt to realign them. You need to fix it anyway, so give it a bend.
« Reply #2 on: August 13, 2023, 04:49:36 PM »
I owned one Accel distributor. Put it on a machine to set the points and found out the cam was ground wrong that some of the cylinders fired at least 3 degrees off. It was new at the time, in '72.
Kelley W King
« Reply #3 on: August 14, 2023, 12:15:02 PM »
When you get new points you should check the face alignment and make should both circles align. Accel points while advertised high perf I believe relates to the spring pressure to keep points from bouncing at high RPM not quality control. Not that I could recommend another brand any better with parts as they are today.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
vetteskip
« Reply #4 on: August 15, 2023, 10:30:01 PM »
Thanks for the input gang!
