Author Topic: Bronze pedal bushings?  (Read 783 times)
USA1968
« on: June 12, 2023, 06:02:50 PM »
Greetings.
I was hoping to find an answer to this.
I have a 1968 Camaro SS. Does anyone make bronze bushings for the brake and clutch pedals?
I can find them for Mopar and BMW's but not Camaro's. All I can find is the plastic ones and people rave about the bronze ones for other makes.
Thank you.
GMAD_Van Nuys
Re: Bronze pedal bushings?
« Reply #1 on: June 12, 2023, 07:39:06 PM »
You might try contacting this manufacturer of bronze bushings with the measurements needed for your 1969 Camaro:
https://www.bronzebushings.com/bushing_finder
Petes L48
« Reply #2 on: June 12, 2023, 08:03:14 PM »
Or you might see if a place like McMaster Carr has something off-the-shelf that would work.  NFI
https://www.mcmaster.com/products/bushings/?s=bronze+bushings
« Reply #3 on: June 12, 2023, 10:00:19 PM »
Hum, Very interesting.
GM Plastic
UPC 7  C2 (CLUTCH)
PC 2
PN3798256
UPC 5  A3 (BRAKE)
PC 3
PN3798256
Establishing same PN for both pedals.
Discussion: The Factory and replacements have a spiral "split" on the inner sleeve portion of the bushings, most brass-bronze bushing are not split. Was this feature for lubricant retention or to allow for tolerance variations on the parts to accommodate "slop" and aide assembly.
This is a good hidden upgrade.
