June 19, 2013, 05:23:47 PM
Search:     Advanced search
83193 Posts in 10595 Topics by 4407 Members
Latest Member: georgeshaw
+  CRG Discussion Forum
| |-+  Mild Modifications
| | |-+  15x8 & 15x10 best backspacing for 1968
« previous next »
Pages: [1] Print
Author Topic: 15x8 & 15x10 best backspacing for 1968  (Read 2480 times)
TStone
Member
1968 Droptop #'s Matching - 327
View Profile Email
« on: April 30, 2007, 05:18:39 PM »
I am ordering new rims for the rear of my vehicle. I'm either going with 15x8's and have std choices of 3.75 or 4.75 backspacing or 15x10 w/ 4.00bs. Any suggestions on what bs to choose for stock suspension. Tire size will liely be 255/60-15 but may want to go 295/50-15's.
Thanx T
Logged
Classics only cost alot if you keep track of what you spend. Smiley
5th Annual Michigan FBody Association Meet & Greet 2009
-= Meet & Greet Official Forum =-
- http://www.mifbody.com/vbullet
hotrod68
Member
rusticman48@aol
View Profile Email
« Reply #1 on: May 29, 2007, 12:11:33 AM »
I put 15x9 Weld Pro Stars on my '68 with 4.75" backspacing. The tires are 11x15x28 Hoosier street slicks. It's very close as far as the shock and tire clearance, but it works. 10" wheels at 4" backspacing should be fine, but will a 10" wheel at 6" positive offset clear your outer wheelwells? It's very hard to stuff a 10" wheel and tire combination into a stock '68 wheelwell without bending the outer quarter panel lip up or jacking the car up in the rear. That's my experience and I hope it helps. Good luck!
Logged
HotRod'68  1968 coupe undergoing frame-off resto/rod. 406/350/4.11s
rat pack
CRG Member
View Profile
« Reply #2 on: June 21, 2007, 10:08:18 AM »
T, I can help you with this later today. Right now I don't have access to the pictures of the two cars here to post. I can tell you one has 10" Cragar S/S wheels with 4.25" backspace with Mickey Thompson Sportsman Pro 28 x 12.50 tires and no tire clearance problems. The other car has 8-1/2" Americans with 3-3/4" backspace, and is running 275/60 BFG T/A's. I think I may have some pictures of American 200s wheels (originals) 10" with 275/60 tires, and US Indy mags 8-1/2" wide, with M/T L60-15 Indy tires. One thing, you cannot run a wheel with more than 4.25" backspacing without getting into the inner wheelhouse. Suspension will also play a role into what hits or fits....................RatPack...............
Logged
TStone
Member
View Profile Email
« Reply #3 on: June 21, 2007, 10:18:03 AM »
thanx for the offer - but it's been all set for a while - i wound up going with 15x8 3.75bs -19mm offset using 295/50-15 tires - they fit perfect no rub anywhere with stock multileaf rears (no coil overs or shackle extenders)
Logged
rat pack
CRG Member
View Profile
« Reply #4 on: June 21, 2007, 10:20:24 AM »
Good deal, just now saw the post. That combo you chose actually works the best. Cool ............RatPack...........
Logged
Pages: [1] Print
« previous next »
Jump to:
Page created in 0.113 seconds with 18 queries.
