Author Topic: Argent Silver/ Krylon dull Aluminum  (Read 14101 times)
Fanthomgreen69
« on: April 06, 2023, 02:10:25 PM »
Tried to find Argent Silver in an aerosol can. Went to Eastwood. Won’t be available until July. OK, I saw that Krylon 1403 Dull Aluminum is a good substitute. Went looking for that at… Walmart, Home Depot, Lowe’s, couple of Hardware stores. Don’t have it. Online….same thing. Not available until 2nd quarter of the year. Is there another substitute silver that Krylon makes that is close to Argent Silver? I like the Krylon because it is made to use on plastic
Charles
Re: Argent Silver/ Krylon dull Aluminum
« Reply #1 on: April 06, 2023, 02:19:42 PM »
Your local paint supplier should be able to mix it for you and put in a spray can. Call ahead to check for availability and price.
Fanthomgreen69
« Reply #2 on: April 06, 2023, 03:08:54 PM »
Contacted an automotive paint supply store & they wanted a paint code. Does anyone have a paint code for Argent Silver?
Sauron327
« Reply #3 on: April 06, 2023, 03:54:06 PM »
WA 3024. I have more paint in stock than I know what to do with. I mix my own for 40 years. Your paint store is lazy. A small amount of work and Argent is not hard to find. Call any jobber and they should be willing to help your shop. Never bought one thing from Eastwood in all those years. Cannot run a shop everyday with supplies from them. Nobody I know who is in the biz can. Bring a sample to any paint store and a blind monkey can match it.
camaronut
« Reply #4 on: April 06, 2023, 04:14:43 PM »
Isn't there a company called "Details" that sells rally wheel paint in aerosol cans?
Sauron327
« Reply #5 on: April 06, 2023, 04:24:26 PM »
There are may companies that sell agent silver. Not sure what the big deal is.
« Reply #6 on: April 06, 2023, 04:30:43 PM »
Sauron Concerning original appearance and techniques, would you advise spraying it out of a gun over an aerosol can to get more of the same type of finish they originally had?
Sauron327
« Reply #7 on: April 06, 2023, 04:49:54 PM »
Will not matter that much with a satin finish. I own a shop and shoot everything from a gun. Again... a one armed blind monkey can do it. Built...not bought.
camaronut
« Reply #8 on: April 06, 2023, 04:58:55 PM »
The reason why folks want the Krylon 1403 is because Jerry McNeish recommends it to be as close to authentic as what the factory used back in the day - something about it having a light green tint to it.
But if all you want is Argent Silver spray paint, that can be gotten almost anywhere I would think.
« Reply #10 on: April 06, 2023, 06:06:15 PM »
I have a partial gallon of Spies Hecker in Argent Silver here. It’s correct. Also have 2 other nice silvers, one with a LOT of metal flake. Thinking about trying that on a wheel to see what it looks like for something different.
Fanthomgreen69
« Reply #11 on: April 06, 2023, 08:39:30 PM »
Thanks to everyone for the input. All I wanted to use it for is paint 2 headlight bezels. Didn’t know it would be that hard to find
Charles
Sauron327
« Reply #12 on: April 06, 2023, 09:27:03 PM »
Cake walk. Hit your local hardware store or jobber
ric1969
« Reply #13 on: April 07, 2023, 12:55:20 AM »
 Keep away VHT paint Argent Silver missing green tinting...
David K
  • Dr. Longblock
« Reply #14 on: April 07, 2023, 01:10:01 PM »
Fathom,
Have you tries the aftermarket car places? Classic Industries,  Camaro Central, etc?
fsc66
« Reply #15 on: April 07, 2023, 02:04:40 PM »
Loads of results on amazon and they also show delivery dates
Searched for Dull Aluminum spray paint, watch though some are gloss and others are metallic for engines
lynnbilodeau
« Reply #16 on: April 07, 2023, 06:03:38 PM »
Would not use Krylon.  Just does not stand up long term. If you want to do it once, buy the good stuff.
169INDY
« Reply #17 on: April 08, 2023, 09:55:24 PM »
Old INFO
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
Sauron327
« Reply #18 on: April 08, 2023, 11:03:54 PM »
The old 5 ball Krylon is good. I'm going to assume most on this site do not do resto, fab, bodywork and custom paint and art like I do 7 days a week. Cake walk to match a color.
169INDY
68 Z28 M21 LOS
Jonesy
  • 1969 Camaro z28
« Reply #20 on: April 11, 2023, 08:39:29 PM »
For my 69Z ralleys, I bought Krylon 1403 online about a year or so ago and it was hard to find then. I was really happy with the results. One thing I noticed it that the wheel codes around the valve stem were very readable. Most paints go on so thick it hides the codes, but not this paint.
I would definitely use it again and wait for it if I had to.
1969 Z28 Azure Turquoise
« Reply #21 on: April 12, 2023, 11:56:01 AM »
Not to turn the subject too far but I have a lot of success with Krylon paints in the can.  Fast drying so you can change the textures of the finish depending on the amounts of coats.  I did the entire dash on my old 67 using Krylon satin (or semi gloss I can't remember now) and then wet sanding and hitting a final top coat.  Rustoleum is good for parts you want to replicate a dipping process as it likes to puddle and run due to the slow dry times.  Just throwing out there some old dumb redneck uses when you don't fill like busting out the paint gun.
crossboss
  • ^ New engine project
« Reply #22 on: April 12, 2023, 03:27:03 PM »
Guys,
I have no problem finding argent silver. My local Home Depot, Lowe's and Wal-Marts have plenty...in different brands, and shades of silver. Its the same situation with my Ford friends trying to find the closest 'Ford blue' engine paint. Also, a tip on some other hard to find color matches: use either Krylon (preferred) or Rustolum 'Bronze Metallic' for what is used for black metallic, with a touch of gold in it. Perfect match...from a rattle can.
1968 Olds 442 W-30
« Reply #23 on: April 12, 2023, 03:54:12 PM »
Cross Boss, anybody can go to HD Lowes and Walmart and find silver paint, but none of them stock the Krylon 1403. I ordered a case of it from my local mom and pop ACE store. Other then that, it is hard to just run across.
David K
  • Dr. Longblock
« Reply #24 on: April 25, 2023, 10:33:09 PM »
D&R had cases of it at Carlisle
« Reply #25 on: April 25, 2023, 11:46:17 PM »
$12 a can? ouch. I think I paid ACE hardware about 5-6 a can, but I bought a case (6).
David K
  • Dr. Longblock
« Reply #26 on: April 26, 2023, 12:32:51 AM »
OP is looking…I found. My job is done.
Jerry@CHP
« Reply #27 on: April 26, 2023, 05:52:49 PM »
The Krylon #1403 dull aluminum is the best out there and spot on color wise, Dave Cunningham who was a trainer at the BASF paint facility here in Jessup, MD also helped with this match and said it's much better to use the #1403 rather than pay more for mixed version.  We've been using it for years.
Jerry
camaronut
« Reply #28 on: April 26, 2023, 06:01:16 PM »
Jerry
Ladies & Gentlemen of the jury - I rest my case.
