Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Restoration
HOOD INSULATION CLIPS
« previous
next »
Print
Pages: [
1
Author
Topic: HOOD INSULATION CLIPS (Read 1710 times)
ALLZS
Member
on:
January 30, 2023, 05:07:27 PM »
ok whats the trick to getting the correct style hood pad clips to stay in on 69 Camaro using the molded pad
Tweet
Logged
Hero Member
Re: HOOD INSULATION CLIPS
Reply #1 on:
January 30, 2023, 06:03:03 PM »
http://www.camaros.org/forum/index.php?topic=16256.msg158199#msg158199
Logged
camaronut
Hero Member
Reply #2 on:
January 30, 2023, 06:32:33 PM »
Get a piece of small o-ring material (1/8" dia. black) cut a small piece off and shove it in between the actual clip part. Spreads it up real nice. Pop it in - yer done. Or - put the clip in the hole, then put the o-ring piece in-between the clips and push it up. Either way you should be good.
Works everytime.
Logged
Dave69x33
Hero Member
Reply #3 on:
February 01, 2023, 05:50:15 PM »
I had the same problem with the original style hood installation clips staying in place on the hood. The problem with the plastic clips is the "hook" is not a sharp corner profile to catch and retain on the sheet metal holes in the hood. I used a sharp box cutter utility knife to carefully trim and remove some of the plastic to form a sharp edge corner. You can also use a sharp corner on a metal file to help form the sharp corner. I am not at home at the moment to share picture how I modified my chips.
Logged
Dave69x33
Hero Member
Reply #4 on:
February 02, 2023, 04:39:54 PM »
Captured these views of the modification I had to make to my reproduction hood insulation clips. The "clip_2" pic shows how the clip retaining stem is molded. The "clip_3" pic shows how I modified it to form sharp lips in the stem to get the clip to stay pushed into the hood.
Logged
camaronut
Hero Member
Reply #5 on:
February 02, 2023, 05:42:37 PM »
I think you'll have one helluva time getting them out if you have to.
Logged
Dave69x33
Hero Member
Reply #6 on:
February 02, 2023, 06:00:02 PM »
Camaronut,
I agree! I also had a helluva time keeping them in place. I recall a couple occasions driving my car shows, open the hood to find a clip missing. Since making this modification…no more missing clips…lol!
I have spare clips if I need one.
Logged
Hero Member
Reply #7 on:
February 02, 2023, 08:21:53 PM »
^^ Same for me^^ Pesky little things
Logged
camaronut
Hero Member
Reply #8 on:
February 03, 2023, 02:52:08 PM »
That's why I just left the clips as they are and used the cut pieces of "O" ring to spread them apart - they can still be removed if needed.
Logged
Dave69x33
Hero Member
Reply #9 on:
February 03, 2023, 03:38:01 PM »
If I need to remove a clip, I use a small flat blade screwdriver or 1” paint scraper to push in on the stem to pinch it inward while pulling downward on the clip.
The o-ring idea is also good advice!
Logged
camaronut
Hero Member
Reply #10 on:
February 03, 2023, 05:58:43 PM »
Yeah - that'll work....
Logged
Print
Pages: [
1
« previous
next »
Restoration
