Author Topic: 69 Temp sender with threads wire mounting sequence  (Read 3125 times)
camaronut
« on: December 01, 2022, 04:49:55 PM »
Ok....I've tried everywhere to get a picture of an original car with the temp sender wiring with console gauges.
I have a kit from HBC that has TWO nuts and the star washer.  I see on the AIM that the wire terminal is put in first, then the star washer - then the nut - then tighten.  Ok - easy.
Am I to believe that I should have one nut tightened onto the sender, then the wire terminal - then star washer - then the other nut and tighten that all together??????
I'm going with the AIM - but are there any original cars out there with two nuts?
Looking for the real experts to chime in!!!!!  LOL!
x66 714
Re: 69 Temp sender with threads wire mounting sequence
« Reply #1 on: December 01, 2022, 05:41:22 PM »
My car is factory with gauges & still has the original sender. 1 nut, 1 lock washer. Not a star washer. With the original sender, there's not enough threads for a 2nd nut.....Joe
camaronut
« Reply #2 on: December 01, 2022, 05:49:07 PM »
Thank you !!!!  Appreciate the help.
x66 714
« Reply #3 on: December 01, 2022, 05:57:28 PM »
You're welcome
camaronut
« Reply #4 on: December 01, 2022, 06:06:44 PM »
Interesting - I looked in the AIM and the part number for that washer is 138479 - which is a "toothed" washer.  Looked it up on AMK and internet search, and its a toothed washer.  Could this be another GM AIM vs reality snafu?  I just found a picture with a cross ram that has what you have - a split lock washer.
Whatever - I have better things to worry about.  LOL
x66 714
« Reply #5 on: December 01, 2022, 09:50:13 PM »
I've had that car since 1981. I always put hardware back where it came off. Between 1970, when the dealer finally sold it & 1981 something could've changed. I wonder what others have on their cars?....Joe
camaronut
« Reply #6 on: December 02, 2022, 11:54:14 AM »
I'm willing to bet yours is correct.  Thanks!!!
Kelley W King
« Reply #7 on: December 02, 2022, 01:15:14 PM »
Not doubting Joe,s car came with a lock washer I think that the star washer is what was intended and should be there.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #8 on: December 13, 2022, 11:02:45 PM »
Agreed, star washers were designed for electrical conductivity....
camaronut
« Reply #9 on: December 13, 2022, 11:19:22 PM »
I decided to use the star washer like is says in the AIM.   Would be nice to see other original cars...
perryrj
« Reply #10 on: December 14, 2022, 04:49:47 AM »
Isn't this the original style sending unit for a 69 with console gauges?
x66 714
« Reply #11 on: December 14, 2022, 11:51:28 AM »
No. That the replacement that some companies sell.
I'm most likely going to change mine to a star washer. What Kurt says makes complete sense.....Joe
« Reply #12 on: December 14, 2022, 04:28:13 PM »
IIRC, that's the style without gauges.
x66 714
« Reply #13 on: December 14, 2022, 07:01:14 PM »
I just did some research on the 138479. I didn't find it in AMK. On GMWikisearch, it says it's a #10 external star washer with a 13/32 o.d., zinc. It's the same lock washer that's used on the starter solenoid & probably many other places. Sorry for the confusion....Joe
« Reply #14 on: December 14, 2022, 07:26:13 PM »
McMaster Carr
   91114A011
