Author Topic: AM antenna  (Read 19342 times)
fireZ
AM antenna
« on: April 26, 2007, 10:51:20 PM »
Can someone let me know what the difference is between a 1968 and 1969 AM antenna. I am finishing up my 1968 Rallye Green Z and want it just right. Thanks
1968 Z28 LA Built
LIC # RPO Z28
KevinK
    • Hudson Valley Camaro
Re: AM antenna
« Reply #1 on: April 27, 2007, 01:51:47 AM »
I'm not sure of the difference (or if there is one) between '68 and '69, ...but having both '67's and '68's with AM radios, ...the antenna you are looking for is a telescopic 'flat' (oval) mast.
  ...these may not be the greatest pics, ...but they are of my '67 with the original mast still intact.
http://i106.photobucket.com/albums/m254/HVClassics/67BlackPlate/67camaro044.jpg
http://i106.photobucket.com/albums/m254/HVClassics/67BlackPlate/67camaro045.jpg
http://i106.photobucket.com/albums/m254/HVClassics/67BlackPlate/67camaro046.jpg
   I do have an NOS GM in the wrapper (I need) but I can grab the number off it if you need...
fireZ
Re: AM antenna
« Reply #2 on: April 27, 2007, 03:40:44 PM »
If you could send me the part#. Thanks in advance for you help.The pics are great
1968 Z28 LA Built
LIC # RPO Z28
Jerry@CHP
Re: AM antenna
« Reply #3 on: April 27, 2007, 03:45:11 PM »
1967 and 68 models are the same.  The bezel is flatter on 69 models, and different.  I should also point out that many in the hobby have distorted the issue on the antenna mast tip stating that all original antennas have a groove in the tip.  They were made both ways, some have it and some don't, so don't let anyone tell you that an original GM antenna has to have the groove in the tip of the mast.
I have three low-maileage survivor cars in my collection and none of them have the groove in the antenna tip.  Have also seen many others the same way........and others with the groove in the tip.
Jerry
Jerry@CHP
Re: AM antenna
« Reply #4 on: April 27, 2007, 03:46:09 PM »
We have some NOS antennas in stock here at CHP.
JM
fireZ
Re: AM antenna
« Reply #5 on: April 27, 2007, 04:05:56 PM »
I called the other day at your shop with no answer,I knew you were probably busy. I will try again this afternoon. What is a good time without bothering you.
1968 Z28 LA Built
LIC # RPO Z28
68rsssrag
Re: AM antenna
« Reply #6 on: April 27, 2007, 11:37:59 PM »
Jerry
Is the bottom bezel the same for a 68 AM and FM anttena?
Arno
fireZ
Re: AM antenna
« Reply #7 on: April 27, 2007, 11:47:45 PM »
Arno I just wondered if you lived in the Hamilton area?
1968 Z28 LA Built
LIC # RPO Z28
Jerry@CHP
Re: AM antenna
« Reply #8 on: April 28, 2007, 01:45:57 AM »
Arno,
Yes, it is the same.  I apologize for my availablility but my Camaro travel these days is off the charts.  Just keep trying either number for me.  This coming week, FL, DE, and MA. all in one week!
Jerry
fireZ
Re: AM antenna
« Reply #9 on: April 28, 2007, 12:07:15 PM »
Jerry I am away all week also .I will try you today and then when I get home next monday. Could you if possible see if you have a antenna for a 68 car with am radio,if so put a hold on it please. Thanks Paul
1968 Z28 LA Built
LIC # RPO Z28
68rsssrag
Re: AM antenna
« Reply #10 on: April 28, 2007, 02:40:08 PM »
firez
I am in Mississauga.
Arno
GaryL
  • Marilyn and me
Re: AM antenna
« Reply #11 on: April 28, 2007, 02:52:23 PM »
I bought what I thought was an NOS antenna w/o the groove. It came in a brown GM package. Thanks for the verification that it could be with and w/o the groove. :)
« Last Edit: April 28, 2007, 09:22:42 PM by GaryL »
Gary
fireZ
Re: AM antenna
« Reply #12 on: April 28, 2007, 03:46:52 PM »
Arno I met you at the Camaro National in Niagara Falls. I have the LA 68 rallye green Z28. I think you know my buddy Dale with the 69 Pace car. Good hearing from you
1968 Z28 LA Built
LIC # RPO Z28
Re: AM antenna
« Reply #13 on: April 28, 2007, 11:40:33 PM »
fireZ -
How long have you owned your '68Z?
Does it have the ivory (code 711) custom interior?
What's the chassis build date?
Do you have the correct DF rally wheels on it?
fireZ
Re: AM antenna
« Reply #14 on: April 29, 2007, 12:04:16 AM »
The car has standard black interior,no console,muncie shifter,correct DFs, 02E build,engine VO205MO ,BU rear ,M-21 that someone before me changed guts to M-22,smog all intact and working,POP,Warranty book,State of California Title ,302 emblems,every body panel is original and I brought it up to Canada in 2002. I did have a lot of body panels to straighten out but was able to save the factory steel. I am a proffesional Fire-Fighter and restored the car at home from top to bottom including paint in my home garage.
1968 Z28 LA Built
LIC # RPO Z28
