Author Topic: Pal-Nuts  (Read 1505 times)
RikerZ28
Pal-Nuts
« on: September 20, 2022, 06:05:51 PM »
Hello All:
Does anyone know what size pal-nuts are used to secure the rear trunk lid emblem (Camaro by Chevrolet) on a 1969 .
To me they look like 8/32?
Thank you all in advance!
Bob
1969 Z/28 02D X-33 / L72
169INDY
Re: Pal-Nuts
« Reply #1 on: September 20, 2022, 07:52:39 PM »
NUT, Hex Flange Stamped, thread cutting
PN 9419753
1/8 HX FLNG STAMPD NUT 5/16 AF .53 D BLK ZC. 10 pk
Source AMK part number B-10629
Now this might be close, the trunk Nut likely had sealer and carried a different Fisher (GM) PN
The pins on the Header and trunk 68/69 emblems are small and I think going off memory they are smaller than say a 8-32 machine screw thread.
Others have better catalogs and parts books and will chime in also.
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
RikerZ28
Re: Pal-Nuts
« Reply #2 on: September 20, 2022, 08:08:39 PM »
Thanks 169INDY for the information
There appears to be a steel sleeve over the pointed cast emblem material. The emblem is stuck in there so I doing want to break it. I did measure the steel sleeve and the OD is .159 and is about 3/16 deep. I'm sure there was some sort of gasket in the pal-nut. Someone before me just use silicone with no nuts to keep the water out of the trunk.
Bob
RikerZ28
Re: Pal-Nuts
« Reply #3 on: September 29, 2022, 04:11:02 PM »
Just a follow up..
The correct Pal-Nuts are Thread cut nut with sealer 1/8" Classic Industries # 11502547.
Bob
