Author Topic: Speedometer Cable Codes  (Read 13486 times)
« on: September 06, 2022, 03:27:19 PM »
I'd like to start a research thread on speedometer cables.  Please add your info below so we can try to determine which cables were used for which applications.
Speedometer Cable Data
Example:
Build date:  01/69
Plant:  NOR / LOS
Stamp Code: CA / CB / ??
Grommet Stamp:  RP / FB / ??
Engine: L35
Transmission: M20
Final Gear Ratio: 3.55P (P = Posi, NP = Non Posi)
Photos if available.
x66 714
Re: Speedometer Cable Codes
« Reply #1 on: September 06, 2022, 03:56:17 PM »
Build date 8/28/1969
plant Norwood
stamp CF
grommet ?
Engine L35
Trans TH400
Gears 3.07 non posi CBL
x66 714
« Reply #2 on: September 06, 2022, 05:02:05 PM »
build date 01B
plant Los Angeles
Stamp CT
Grommet ?
Engine ss350
Trans TH350
Gears 3.07 non BL
« Reply #3 on: September 06, 2022, 05:13:22 PM »
Thanks Joe!
Keep them coming!
x66 714
« Reply #4 on: September 06, 2022, 05:48:00 PM »
Waiting on Guy with his 375hp, m22 car. My z has a replacement...Joe
R68GTO
« Reply #5 on: September 06, 2022, 10:41:24 PM »
Build Date: 9/26/69
Plant: Norwood
Stamp: CW
Grommet: ?
Engine: L72
Trans: M22
Gears: 4.10 posi BE
1969 427 COPO Camaro Lemans Blue/Black, M22 4 speed, 15,500 original miles
« Reply #6 on: September 06, 2022, 11:10:28 PM »
Awesome. Thank you Jim.  Just a heads up to anyone else I don’t need the actual date it left the plant but just the build date on the trim tag.  Thanks again and keep them coming!
« Reply #7 on: September 07, 2022, 03:18:35 AM »
1968
Build date: 01B
Plant: NOR
Stamp Code: CA
Grommet Stamp: FB
Engine: Z28
Transmission: M21
Final Gear Ratio: 4.10P
Post #510 below
https://www.camaros.net/threads/time-for-another-68-z-28-to-be-restored.182584/page-26#post-1707377
uscrichter
« Reply #8 on: September 07, 2022, 03:44:49 PM »
Here's a two for one! Double stamp.
69 Z NOR
08C
Stamp(s) CH and CX
M22
« Reply #9 on: September 07, 2022, 04:33:30 PM »
69 Z NOR
08C
Stamp(s) CH and CX
M22
Aug of 68 or Aug 69?
Also differential ratio and code if you know what it was originally.?.
1968
Build date: 01B
Plant: NOR
Stamp Code: CA
Grommet Stamp: FB
Engine: Z28
Transmission: M21
Post #510 below
Thanks Chick!
uscrichter
« Reply #10 on: September 07, 2022, 05:32:42 PM »
08C '69 X33 D80 Sorry, I don't know original rear.
« Reply #11 on: September 07, 2022, 05:38:05 PM »
That's ok and thanks for the info.
« Reply #12 on: October 03, 2022, 06:03:13 PM »
Still looking for more examples.  Thanks!
x66 714
« Reply #13 on: October 04, 2022, 12:30:12 AM »
Guy's 375hp, M22 3.73, Norwood car uses a "CF". April built....Joe
« Reply #14 on: October 04, 2022, 11:41:04 AM »
Thanks!
« Reply #15 on: October 22, 2022, 04:15:16 AM »
Date matters, auto vs man trans matters, speedo adapter probably matters. But the usage sometimes changes for unknown (to me) reasons.
Here's what I have for 69 (with a caveat for limited data):
CF (May & later) - V8 auto, Z28, BB auto & man
CT (pre May) - V8 auto, Z28, BB man
CV  (pre May) - L6 & low-po auto
CW - L48/M20, BB auto & man
CX - L65 & L14 man
CY - L65 man
CH is a full-size code. And I've not seen a CX code on a Z, so I think that cable was changed.
jbtech
« Reply #16 on: December 02, 2022, 03:03:52 AM »
Thanks Troy Abercrombie for submitting this info to me:
1967 Camaro SS 396 4 speed
Build date:  06E
Plant:  NOR
Stamp Code: CA
Grommet Stamp:  (TBD)
Engine: L35
Transmission: M20
Final Gear Ratio: (TBD)
Jose
67 Camaro L78
124377N212598
jdv69z
  • 69 RS Z/28 52E
« Reply #17 on: December 02, 2022, 03:23:24 PM »
Where is the cable stamped? Can I see it easily? Pretty sure mine is original.
Jimmy V.
KevinW
« Reply #18 on: December 02, 2022, 03:28:37 PM »
Great info!
CW - L48/M20, BB auto & man (is what I need for my car)
But it would be good to know the original lengths.  I am confused with the lengths the repros are available in.
Thanks!
David K
  • Dr. Longblock
« Reply #19 on: December 03, 2022, 05:18:13 PM »
Jdv69z, see post 5…might help.
« Reply #20 on: December 03, 2022, 06:40:35 PM »
There’s no one spot the cables are stamped.  You will just have to look the cable over completely but I’d start at the trans and work towards the firewall.
x66 714
« Reply #21 on: December 03, 2022, 08:07:53 PM »
Mine was about half way but the next car might not be....Joe
R68GTO
« Reply #22 on: December 04, 2022, 02:44:00 AM »
Mine is stamped right near the trans fitting
« Reply #23 on: December 17, 2022, 04:06:18 AM »
I'm playing catch-up to posts.
Below is what the 67 LOS has.
Build date: 04B (04/13/1967)
Plant: LOS
Stamp Code: CA
Grommet Stamp: RP
Engine: L35
Transmission: TH400
Final Gear Ratio: 3:07  Rear Prefix- 0404 BJ
« Reply #24 on: December 18, 2022, 03:14:45 AM »
Awesome thank you Mike.!!.
169INDY
« Reply #25 on: December 19, 2022, 04:02:29 AM »
Below is what the 68 LOS has.
Build date: 12E (01/03/1968)
Plant: LOS
Stamp Code: CA
Grommet Stamp:
Engine: L35
Transmission: TH400
Final Gear Ratio: 3:07  Rear Prefix- PP  1216 G1
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
169INDY
« Reply #26 on: December 19, 2022, 04:15:44 AM »
Below is what the 69 Z11 has.
Build date: 04C (04/21/1969)
Plant: VN (LOS)
Stamp Code: CV
Grommet Stamp:
Engine: L48
Transmission: TH350
Final Gear Ratio: 3:07  Rear Prefix- BL  0326 G2
68 Z28 M21 LOS
