Author Topic: Painting the RS grill  (Read 4624 times)
Re: Painting the RS grill
« Reply #15 on: August 02, 2022, 06:00:54 PM »
There's a caveat to what Bill posted as mentioned HERE.
Quote
Apparently with the changeover to the all black grille, the 67 covers (with the part numbers molded on the back side), were utilized on the late year 68's. It is speculation only, but this may have been necessary as a shortage of black 68 headlight covers may have existed or perhaps a way to reduce leftover 67 cover inventory.
« Reply #16 on: August 02, 2022, 06:41:01 PM »
Sounds like BS to me.
Back in '83 when I became involved in the parts biz, it was 85% GM and 15% repro. The 67-68 RS grille and head lamp covers as serviced by GMPD were production '68 parts with the raised horizontal ribs. Our '67 Z/28 project had a cosmetic resto in the '70s and had incorrect '68 parts as purchased. We located production '67 RS parts for the resto.
45 years in manufacturing tells me GM revised the '67 grille and headlamp cover tooling for the '68 change. Since they interchange and are virtually identical there was no reason to continue producing '67 parts.
The 11-68 P & A manual lists 3919060, 3919063 & 3919064 for 67 - 68 RS.
David K
  • Dr. Longblock
« Reply #17 on: August 03, 2022, 01:01:55 AM »
William, I’m not sure what BS you’re referring to.
« Reply #18 on: August 03, 2022, 01:51:23 AM »
That late '68s were built with '67 covers.
Sales & Operations Planning tells you how many of all components are needed for the production run. 40,000 RS are planned over 50 weeks; 800 pair of covers per week. The tooling is designed for that production rate; Production Control knows it can't schedule more than 800 RS per week. As simple as it seems.
Short of a major tooling failure, not much to go wrong. The only way you're going to 'run out' of anything is to over-release orders. Even the crude systems back in those days must have had some way to material-assure a build order.
Did production scheduling and inventory planning my last 15 years in industry. Much tougher now with parts coming from all over the world, many sitting in cargo containers in the port.
« Reply #19 on: August 03, 2022, 03:05:48 AM »
Ask Steve (the author of the article) for the data he had on late '68's. He didn't write that without data justification.
Gars68Tux
« Reply #20 on: August 03, 2022, 09:36:43 AM »
David's 68 is an 11E build. I think it's safe to say the headlight doors would've had raised horizontal ribs (with chrome) the same as the grill.
Garth
68 RS L30 AA 749 Fred Gibb Chevrolet
David K
  • Dr. Longblock
« Reply #21 on: August 04, 2022, 12:50:41 AM »
I’ve seen some on eBay that were service replacements with the correct part numbers. The raised ribs are there but no chrome. I wonder how this got rectified if a grill/door was damaged and needed replacement. Thinking the dealer  body shop painted it chrome before install.
I’m no authority on 1968 part labels, but if anyone can verify the vintage…… The ones I saw have these and are most likely modern, but I don’t know. Zoom in to see.
Here’s 2 examples
https://www.ebay.com/itm/304496814569?epid=1830485962&hash=item46e56ca9e9:g:zPkAAOSwPjpiiM7x
Gars68Tux
« Reply #22 on: August 04, 2022, 01:06:34 AM »
From the report linked above;
Quote
The 68 service parts were probably the same as the production parts. So the 68 service parts were probably chrome up to the May 68 timeframe and then supplied as unchromed from then on. To that end, the below picture shows one of two observed "new in the box" service grilles which are black. If a 68 chrome grille needed to be replaced and a NOS chrome grille was not available, the replacement black 68 grille would have been painted to match the original chrome doors. The first "Note: paint as required" is found no earlier than October 1968 for the headlight covers. So far, December 1971 is the earliest such a note is found for the center grille.
I couldn't tell ya the vintage of those on ebay, but I'm sure they're genuine. I bought the entire grill ("over-the-counter") around 1990 and of course there was no chrome.
Garth
Gars68Tux
« Reply #23 on: August 04, 2022, 01:31:29 AM »
Dunno where you got the photo above, it's not in the ebay ad that you linked? I'm not familiar with that tag at all.
9063 & 9064 are 68 production numbers and also 67/8 service part numbers.
Garth
David K
  • Dr. Longblock
« Reply #24 on: August 04, 2022, 02:39:01 AM »
Correct Gars…I added the picture because of the older looking label…and was hoping for some insight…vintage or timeline.
Here’s the other I meant to include.
https://www.ebay.com/itm/304183016230?fits=Year%3A1968%7CModel%3ACamaro&epid=654199008&hash=item46d2b87b26:g:SXwAAOSwYaJhZd0D
David K
  • Dr. Longblock
« Reply #25 on: August 06, 2022, 01:22:42 AM »
So is it safe to speculate the service replacement for a 68 had chrome from the parts department until the supply ran out? Then it was all black that needed to be painted to match?
« Reply #26 on: August 06, 2022, 06:27:44 PM »
It is possible they were supplied with the faux chrome during the '68 MY, but not much longer. In my 15 years of ordering/selling parts, GM had no qualms at all about furnishing a part that fit and functioned but didn't necessarily look the same. A few examples:
When ’68 Z/28 chrome rocker covers were ordered they substituted ‘69 Corvette L79 covers.
When '69 BB chrome rocker covers were ordered they substituted ’71-up covers with the snap-in rubber oil cap and lousy chrome.
When a ’69 Camaro rear license plate bracket was ordered, they substituted the 73-up Nova bracket.
When ’69 Camaro 396 fender emblems were ordered, they substituted ’70 Nova emblems
When ’68-69 Camaro rear spring anchors were ordered, they substituted ’70-up anchors with the sway bar tabs.
When a ’67-’69 12 bolt axle cover was ordered, they substituted a ’70-up cover notched for a rear brake hose bracket.
The Aug '71 P & A manual lists only the '68 part numbers with a note.
rich69rs
  • LF7/M35/Z22/Z87
« Reply #27 on: August 07, 2022, 05:37:55 PM »
The one that has always tickled my fancy is carburetors.  Originally, carb was spec out/had a part no based on car, options, etc., i.e. Camaro vs …., transmission, ac vs non-ac applications, etc.  Service replacements lost that delineation and pretty much became a one or two part number for all applications - if it fits it works.
Richard
Richard Thomas
1969 RS
