Author Topic: Idels rough, but runs smooth  (Read 4694 times)
Kevs67
« on: April 21, 2007, 10:11:18 PM »
My 67   327/275   Idles rough.  It runs like a top going down the road, but when I stop it idles rough.  I know that I am being very vague but could use some where to start.
« Last Edit: April 21, 2007, 11:23:21 PM by Kevs67 »
Re: Idels rough, but runs smooth
« Reply #1 on: April 21, 2007, 10:12:48 PM »
Vacuum leak. Check all your vacuum hoses for splits, cracks, loose connections, etc.
Ed "Bert" Bertrand
email me!
Kevs67
« Reply #2 on: April 22, 2007, 04:25:21 AM »
I replaced all vacuum hoses etc...  It helped a little but still rough in Drive with the brake on...
deejaygee
« Reply #3 on: April 22, 2007, 05:02:00 AM »
Start with the obvious. Check choke operation while engine is warming up, and adjust if necessary. If running a points distributor, check and adjust the dwell; then timing, then idle speed. Test idle speed with car in gear.
rich69rs
  • LF7/M35/Z22/Z87
« Reply #4 on: April 22, 2007, 04:05:43 PM »
I had this happen about 10 years ago one day while I was driving my '69 RS to a weekend cruise in at a town about 50 miles away.  When I started the car up at the house, everything was fine, good idle, etc.  I left for the cruise and when I exited the interstate and came to a stop at the end of the exit ramp the car was idling very rough and died.  It started right back up but idled badly.
I checked all of the vacuum lines as well, found nothing, then noticed a gap between the base of the carb and the intake manifold where there no longer was any gasket material.  To this day, I never did figure out why the gasket failed - but there was my vacuum leak.  Pulled the carb, installed a new gasket, and all was well.
Definitely sounds like vacuum leak somewhere.  If it isn't the obvious (hoses) then you have to start looking for where a vacuum leak can occur, may not be a likelly candidate, but after eliminating the hoses .........
The car runs fine going down the road because the extra air being drawn into the engine via the vacuum leak isn't enough to lean out the air/fuel mixture while you've got your foot in the throttle.  At idle - too much air.
« Last Edit: April 22, 2007, 04:10:07 PM by rich69rs »
Richard Thomas
1969 RS
Kevs67
« Reply #5 on: April 23, 2007, 12:13:19 AM »
That did it, I replaced all vacuum hoses, plugged the lines that were open, etc., that helped some, but then I replaced the carb gasket and tadaaaaaaaaa.  that did it.  Thank you, bertfam, deejaygee and rich69rs.  I owe you guys a drink !!!
« Last Edit: April 24, 2007, 06:04:22 AM by Kevs67 »
