Author Topic: Decoding a "68 z28 302" by the pad stamps?  (Read 4042 times)
itsazooitellya
« on: April 26, 2022, 10:06:13 PM »
Can anyone help me with these pad stampings? I included the block and head numbers although the heads are newer. It is "supposed" to be a Chevy 302 out of a 68 z-28. Is it? If not what the heck is it??
x66 714
Re: Decoding a "68 z28 302" by the pad stamps?
« Reply #1 on: April 26, 2022, 10:15:51 PM »
124378N455370 was the car the 1968 302 was in. Engine was built in Flint June 10th 1968....Joe
itsazooitellya
« Reply #2 on: April 26, 2022, 10:25:03 PM »
Thank you, so the stamping looks legit?
« Reply #3 on: April 26, 2022, 11:09:23 PM »
Pad is good IMHO
itsazooitellya
« Reply #4 on: April 26, 2022, 11:14:04 PM »
MO
« Reply #5 on: April 27, 2022, 04:40:21 AM »
Three months from casting to build?
« Reply #6 on: April 27, 2022, 12:07:01 PM »
Heads aren't correct.  I don't see anywhere that shows the block casting date?  My comment was strictly about the pad stamp.
itsazooitellya
« Reply #7 on: April 27, 2022, 12:43:06 PM »
This it?
« Reply #8 on: April 27, 2022, 12:57:11 PM »
Yep and doesn't change my previous opinion on the stamp.
itsazooitellya
« Reply #9 on: April 27, 2022, 01:14:56 PM »
Okay, thanks again
jdv69z
  • 69 RS Z/28 52E
« Reply #10 on: April 27, 2022, 02:38:52 PM »
So is that block cast date E228?
Jimmy V.
« Reply #11 on: April 27, 2022, 04:11:57 PM »
That is what I am seeing.
« Reply #12 on: April 27, 2022, 08:24:27 PM »
I see the same, which falls right in line with the Assembly date.
itsazooitellya
« Reply #13 on: April 28, 2022, 11:48:21 PM »
UPDATE: After further inspection, the engine is sized, has mismatched pistons, and a crank with the number 3941174, 327? So now my question is what is just the block worth? It is currently still 4” bore. The windage is intact also. Trying to decide whether I walk away or not. Does seem like the block should be with something though. 🤷‍♂️
« Reply #14 on: April 29, 2022, 12:00:55 AM »
It’s only going to be worth the most to the person with the car.  Oddly enough I have another Z 1,000 vins off this one in my data.  Just the block can go anywhere from $1k-3k depending condition.
