Author Topic: Factory Axle Stamp?  (Read 1248 times)
uscrichter
Factory Axle Stamp?
« on: March 28, 2022, 10:03:04 PM »
I was bead blasting my 12 bolt 4:10 rear end I had bought a few years ago and noticed grinding marks once the old paint was blasted off, it's not original to my car however I will be using it and just wondering if the factory did that?, are they original stampings?, also you can see the "E" stamped twice.
mls68z28
Re: Factory Axle Stamp?
« Reply #1 on: April 03, 2022, 09:16:33 PM »
Rear axle stamp,,8N420159,04D.
Mitch,1968 Z28 03C Norwood,03/18/68,Seneca Falls NY,Z/28 Emblems.Purchase 05/04/78
« Reply #2 on: April 04, 2022, 02:19:45 AM »
Stamp looks legit to me.
1968 - Rallye Green L78 unrestored
1968 - Matador Red Z28 - Currently under preservation
If you have solid lifter 1967 - 1969 Camaro please contact me as I would like to add your car's info to my database
« Reply #3 on: April 04, 2022, 11:44:44 AM »
uscrichter can you post a photo of your stamp.?
Pacecar
« Reply #4 on: April 04, 2022, 05:19:41 PM »
If it was a late build rear axle, then it might have been stamped originally CBV and the factory would have ground off the C
« Reply #5 on: April 05, 2022, 01:12:58 AM »
Haven’t seen a ground off C.  More like a peened C.
uscrichter
« Reply #6 on: April 06, 2022, 08:13:59 PM »
Here is the stamp in question
R68GTO
« Reply #7 on: April 07, 2022, 01:11:06 AM »
Same date as my BE rear.  That grinding looks like someone tried to clean off rust to read the stamp vs anything the factory might have done.  If the factory did it, it would be very intentional to eliminate worn numbers IMO
1969 427 COPO Camaro Lemans Blue/Black, M22 4 speed, 15,500 original miles
« Reply #8 on: April 07, 2022, 02:04:04 AM »
Casting date?   Stamp appears legit.
« Reply #9 on: April 07, 2022, 05:24:32 AM »
Rotated.
uscrichter
« Reply #10 on: April 07, 2022, 08:55:18 PM »
Here's is the date code. E 25 8
