Author Topic: 69 Front Caliper Restoration  (Read 1921 times)
gbowman
« on: March 06, 2022, 09:15:25 PM »
Looking for tips on caliper restoration as to the do's and do not's. Can they be safely bead blasted, etc... Short of installing on the car, is there any way to bench test the pistons to make sure they're not seized up? Any and all tips will be much appreciated. Thanks in advance.
68 RS/SS 396
69 X11 SS
Re: 69 Front Caliper Restoration
« Reply #1 on: March 07, 2022, 12:57:42 AM »
When all is said and done, paint them black, just like the factory did. Blue caps on the bleeders.
169INDY
« Reply #2 on: March 07, 2022, 02:24:27 AM »
Gosh, I was looking for photos of my Pacer caliper rebuilds I did a few years ago, Now I sure think the single piston versions are very DIY friendly and the seal & Oring kits are very affordable, seating the seal and installing the piston past its installed o-ring with out injuring the Oring are but a few of the details I can vaguely remember. I can not remember if I had to polish the bore ever so slightly, new bleeder screw, new mounting bolts and slider o-rings and a splash of black paint, etc.
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
x66 714
« Reply #3 on: March 07, 2022, 02:36:39 AM »
Calipers should look something like these when done.  (Don't look at the bolts on the upper ball joints. I couldn't find anybody to rivet during Covid)...Joe
gbowman
« Reply #4 on: March 07, 2022, 12:59:42 PM »
Thanks for all the pics, they're very helpful. Can anyone chime in on the actual process of cleaning the calipers and testing the pistons to make sure they're free? Thanks again.
Gary
68 RS/SS 396
69 X11 SS
x66 714
« Reply #5 on: March 07, 2022, 02:04:22 PM »
I can't believe there's not a GOOD youtube video on caliper rebuild. This one will give you an idea. Use a large "C" clap & wood to move the piston back into the caliper. Maybe somebody knows of a better video....Joe
https://www.youtube.com/watch?v=rvbiiQKHlhU
« Reply #6 on: March 07, 2022, 04:53:05 PM »
Air pressure in the rear to blow the piston out for rebuild... hone the cylinder and install the kit. They are very easy to do.
BillOhio
    • photobucket
« Reply #7 on: March 07, 2022, 09:34:12 PM »
I got my parts at NAPA and real easy to do
1968 RS 327 4 speed
